[Mapserver-users] OGR Layer with SQL
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 28 15:21:03 EDT 2004
Blaine Hackett wrote:
> All
> I am having a problem using SQL with OGR. The
> following SQL statement works:
> <SrcSQL>SELECT * FROM subset (time > '6:00:00 AM'
> </SrcSQL>
> but if I make it complex like this:
> <SrcSQL>SELECT * FROM subset (time > '6:00:00 AM') AND
> (time < '7:30:00 AM') </SrcSQL>
> It throws this error:
> msOGRFileOpen(): OGR error. Open failed for OGR
> connection ` ODBC:ODBC:user/pass at minnesotadata SELECT
> * FROM subset (time > '6:00:00 AM') AND (time <
> '7:30:00 AM') wkbPoint WGS84 '. File not found or
> unsupported format.
Blaine,
Based on the error message, I would say somehow the SQL statement is
getting mushed into the datasource name itself. Can you provide your
whole .ovf file for me to look at?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
