[Mapserver-users] IMSEMU trouble with <GET_SERVICE_INFO>
Hancock, Eric
Eric.Hancock at dep.state.fl.us
Wed Jul 28 15:35:15 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C474DA.0180589C
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
I've included the output of the sniff from the beginning of when ArcMap =
first
connected to the emulator. This may help a little since it looks like =
the
problem didn't originally start out with setimage. It looks like it gave =
that
error after several try's.
-Eric
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Wednesday, July 28, 2004 1:41 PM
To: Lowell Filak
Cc: Hancock, Eric; mapserver-users at lists.gis.umn.edu;
mleslie at refractions.net
Subject: Re: [Mapserver-users] IMSEMU trouble with <GET_SERVICE_INFO>
Yes, Lowell is right, the snippet below is the transaction that fails. =20
The setImageType method is a perl mapscript method, and if it is being=20
called on an undefined value, that probably means the $map object is=20
not getting properly initialized. Which in turn could mean that the=20
path to the map file (/var/www/html/tutorial/example1-1.map) given in=20
the imsemu is not correct.
1380 [Wed Jul 28 09:15:16 2004] [error] [client 199.73.157.80] =20
[09:15:16] Service: /var/www/html/tutorial/example1-1.map
1381 [Wed Jul 28 09:15:16 2004] [error] [client 199.73.157.80] =20
[09:15:16] XML: <?xml version=3D"1.0" encoding=3D"UTF-8"?><ARCXML=20
version=3D"1.0.1"><REQUEST><GET_SERVICE_INFO dpi=3D"96"=20
toc=3D"true"/></REQUEST></ARCXML>!
1382 [Wed Jul 28 09:15:16 2004] [error] [client 199.73.157.80]
1383 [Wed Jul 28 09:15:16 2004] [error] [client 199.73.157.80] =20
[09:15:16] Doc: ARRAY(0x843e0f8)
1384 [Wed Jul 28 09:15:16 2004] [error] [client 199.73.157.80] Can't =
call method "setImageType" on an undefined value at=20
/var/www/cgi-bin/com.esri.esrimap.Esrimap line 201, <> line 1.
On Wednesday, July 28, 2004, at 09:16 AM, Lowell Filak wrote:
> Are you using the default "/home/www/mapserv/maps/92k.map" mapfile=20
> (line
> 21 in my version of imsemu)?
> It appears from the error log that there is a failure opening the=20
> mapfile.
> Lowell
> The following message was sent by "Hancock, Eric"
> <Eric.Hancock at dep.state.fl.us> on Wed, 28 Jul 2004 09:43:47 -0400.
>> Hello all,
>> I'm new to the list and I'm having a bit of a problem with IMSEMU.
>> I suppose I should introduce myself. My name is Eric Hancock and I
> work > for
>> the Florida State Department Of Environmental Protection in the=20
>> BIS/GIS
>> section and am currently looking into open source solutions for our=20
>> GIS
>> department.
>> The problem:
>> We've installed mapserver and its serving maps and the demo we have >
> works
>> fine, however IMSEMU is giving us some problems. IMSEMU is returning =
a
>> version reply, so the perl script seems to be executing fine. =
However,
>> when
>> the client (in our case ArcMAP) sends a <GET_SERVICE_INFO> request >
> IMSEMU
>> crashes and returns an HTML error. I will attach the ngrep'd request=20
>> and
>> response as well as the apache error log file. I know just a little
> perl > so
>> debugging perl is not completely out of the question. Has any of you
> ran > into
>> this problem? What steps could I take to troubleshoot it farther?
>> Thanks for your help,
>> Eric Hancock
>> <<trouble.txt>>
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
name="results.txt"
Content-Transfer-Encoding: base64
Content-Description: results.txt
Content-Disposition: attachment;
filename="results.txt"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------_=_NextPart_001_01C474DA.0180589C--
