[Mapserver-users] help
pablo schmitt
pablo_schmitt_ at hotmail.com
Thu Jul 29 09:31:19 EDT 2004
hello friends
i need some help from you
this is a brief description of my problem:
i have a grupos2002.shp file uploaded into mysql using the shp2mysql.lp, and
it is working properly
this script generated the following tables geometry_columns, grupos2002,
grupos2002_bin, grupos2002_num
, spatial_ref_sys
in the map file i have this definition for the connection and data:
CONNECTION "localhost:gisusr:gis:gisdb:bin:"
DATA "geometry from grupos2002 feature, grupos2002_bin geometry"
and it is working fine
my problem is:
i have a table zonas with the following fields:
1- f_Zona ( olso located in grupos2002 )
2- Description
3- Atributos
so, i need to use the field number 2 ( Description) as Label in the map and
i need to apply some filters using the field number
3 (Atributos).
THE BIG CUESTION IS: how should i contruct my DATA definition in the map
file ????
i hope you could understand me
thank you very much
by
pablo schmitt
municipalidad de malvinas argentinas
dep. informática
_________________________________________________________________
Consigue aquí las mejores y mas recientes ofertas de trabajo en América
Latina y USA: http://latam.msn.com/empleos/
