[Mapserver-users] off topic - urgent help needed (ArcIMS +Tomcat +Apache)
Andrew Haigh
andrew at andrewhaigh.net
Thu Jul 29 13:21:21 EDT 2004
Evening.
I've installed ArcIMS 4.0.1 on Windows (2000 Pro & Server & XP Pro)
it's normally quite easy providing that you following the instructions
on the ESRI website the letter.
The Windows installation guide is at
http://support.esri.com/index.cfm?
fa=knowledgebase.techarticles.articleShow&d=24171 and the full version
of the windows user guide is at:
fa=knowledgebase.documentation.viewDoc&PID=16&MetaID=81
When you've done the install, goto:
fa=downloads.patchesServicePacks.listPatches&PID=16&FilterPV=43&FilterTy
pe=8%2C5 and install all of the patches.
Best bet is to install on a clean machine and check the userguide /
forums as you can't use ArcIMS on a machine that has some thrid party
software and certain ESRI products (ArcGIS 8.x or 9.x, ArcGIS Server or
ArcGIS Engine).
If that fails using IIS and Jrun (which comes on the ArcIMS CD for
development purposes) and search the ESRI support site for instructions
on IIS Jrun and ArcIMS 4.0.1.
If you only have ArcIMS 4 the above links will be wrong but searching
on support.esri.com will find the correct versions of the
documentation.
Hope this helps,
Andrew
On 29 Jul 2004, at 02:30, Martin Tomko wrote:
> Hi list!
> I am seeking a help here because even google failed. I have to
> unvolountarily install ArcIMS (for demonstration only, we developm on
> Mapserver.)
> To keep the list quiet, please, reply to my address, not to the list.
> Thanks!
> I am getting desperate and I seek somebody having experience with the
> combination ArcIMS (4), Apache and Tomcat. (I have found bart's web
> site, but it is for older versions of the two and doesn't work
> anyway... :(( My problem is that ArcIMS complains that it cannot
> communicate with Tomcat. I have narrowed down the problem to the
> correct configuration of mod_jk, to make the two communicate. (Both
> work fine on a standalone basis). Could you please give me a hint
> about the correct combination of versions and the configuration of
> httpd.conf, and server.xml?? I am working on Windows XP. I have the
> following versions of software available:
> Apache 1.3.31
> Apache 2.0.49
> Apache 2.0.48
> mod_jk2.dll 2.0.48
> mod_jk.dll (dunno which version.. might be the problem...)
> Tomcat 3.3.2
> Tomcat 4.1.30
> ArcIMS 4.
> I have spent weeks searching on the web, googling, searching google
> groups and so on... It seems that there are lots of people having this
> sort of problem, not only ArcIMS connected...
> Thanks for any help!! Snippets of httpd.conf, server.xml, a correct
> dll, anything!! This is the best list I have ever been to, so I give
> my destiny in your hands once again :))
> Martin
> Ing. Martin Tomko
> PhD. candidate
> CRC for Spatial Information
> Department of Geomatics
> University of Melbourne
> Victoria 3010
> Australia
> phone +61 3 8344 9179
> fax +61 3 9349 5185
> email m.tomko at pgrad.unimelb.edu.au
> url http://www.geom.unimelb.edu.au/tomko
> url http://www.spatialinformationscience.org
> url http://www.spatialinfocrc.org
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
