[Mapserver-users] Installing Python Mapscript
Sean Gillies
sgillies at frii.com
Thu Jul 29 13:56:26 EDT 2004
On Jul 29, 2004, at 11:08 AM, William Hudspeth wrote:
> Hello all,
> I am trying to install Python Mapscript. I have run "python setup.py
> install" in the /mapscript/python directory. When I try to import
> mapscript,
> >>>import mapscript
> I get :
> ImportError: No module named _mapscript
> What might be the problem?
> Thanks, Bill
Bill,
Here's my first guess at the problem, a gotcha that I've experienced.
The mapscript module is configured in such a way that the
Python interpreter expects to find both mapscript (aka mapscript.py)
and _mapscript (aka _mapscript.so or _mapscript.pyd) side-by-side
somewhere in your PYTHONPATH.
After the install, mapscript.py and _mapscript.so (I'm assuming linux)
are copied to /usr/lib/python/lib/site-packages or something like that.
However, the current working directory remains at the head of your
PYTHONPATH. This allows modules in your working directory to override
installed modules.
At any rate, change directory to any other location, and try again
to import mapscript -- you'll get the installed modules.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
