[Mapserver-users] SWF multiple output, ElementSelected when a layer is off
Pierre GIRAUD
bluecarto at free.fr
Fri Jul 30 06:08:53 EDT 2004
Hello all,
I'm just trying to implement the flash output and I gotta some problems
using the multiple one.
1 - Imagine you've got a mapfile with two layers :
LAYER
NAME layer1
TYPE POLYGON
DATA "layer1.shp"
CLASS
END
METADATA
"SWFDUMPATTRIBUTES" "LAYER1_FIELD"
END
END
LAYER
NAME layer2
TYPE POLYGON
DATA "layer2.shp"
CLASS
END
METADATA
"SWFDUMPATTRIBUTES" "LAYER2_FIELD"
END
END
If I use the multiple output, Mapserver renders a main swf movie
(file_name.swf)
that contains a mapObj object with many variables in it, and a movie for
each
layer (file_name_layer_0.swf, file_name_layer_1.swf). I am developping an
interface that can return infos when the mouse rolls over elements
(shapes). This works well in this configuration.
mapObj.layers contains 2 objects, one for each layer with variables like
fullname, name, relativename, etc ...
2 - Now imagine you add a MAXSCALE to the first one (layer1) that
prevent it to be rendered.
Mapserver generates the parent movie (file_name.swf) and only one child
movie (file_name_layer_0.swf).
Here is the mapObj object returned (in the parent movie) :
mapObj
.layers
.0
.fullname : "/var/www/.../file_name_layer_0.swf"
.name : "layer1"
.relativename : "file_name_layer_0.swf"
.type : "2"
.name : "MYMAP"
.numlayers : 2
First of all, this may not be correct. There are 2 layers in the mapfile.
Logicaly only one is rendered. But the one that is included in mapObj is
not the
right one.
Following would probably be better :
mapObj
.layers
.0
.fullname : undefined
.name : "layer1"
.relativename : undefined
.type : "2"
.1
.name : "layer2"
.type : "2"
.name : "MYMAP"
.numlayers : 2
3 -The main problem rise up when trying to use the AScript
"ElementSelected" function. Its first argument returned is the
"layerId". It corresponds to the layer order in the mapfile. In the
second example, when rolling over a shape of layer2 (the only one
visible), "layerId" is equal to "1" (second layer in the mapfile). But
there is no data relative to it in "mapObj.layers".
The example of maxscale value is one among many others. The problem
obviously
appears as well when layer status is dynamically set to off.
4 - Is this a bug ? Is there any other way to get the attributes
corresponding to the layer the mouse is rolling over ? Am I missing
something ?
Regards
Pierre GIRAUD
