[Mapserver-users] Mapobj between severals php scripts
Sean Gillies
sgillies at frii.com
Fri Jul 30 11:07:11 EDT 2004
The query result set is one of the reasons that you can't share a mapobj
between different processes or threads. There could be collision
between queries.
Sean
On Jul 30, 2004, at 8:41 AM, Stéphane RIFF wrote:
> In fact i want to use the same mapObj in two script. This two script
> are in two different frame
> and i want to use the map object in the two script. I tested with php
> sessions but it doesn't work, i tried with $map->save('filename')
> but this doesn't store the query result so i ask your advices
> Hope this one is more explicit
> Thanks
> Merlos wrote:
>> Your question is not very explicit. What do you mean with share?
>> Maybe you are not referring to this, but, in general, if you define a
>> variable in the "main" function of a php script it is accessible in
>> all included scripts or using the global keyword in functions, but
>> this is something general on the php language, it is not a
>> particularity of the phpmapscript.
>> <?php
>> //first.php
>> //Define the map as global
>> $map = ms_newMapObj('mymap.map');
>> include ('second.php');
>> <?php
>> //second.php
>> function mydraw () {
>> global $map;
>> $img= map->draw();
>> $ext = $map->getExtent();
>> mydraw();
>> On Friday 30 July 2004 14:36, Stéphane RIFF wrote:
>>> Hello
>>> I want to know if it's possible to share a map object create with
>>> phpmapscript between multiple script ???
>>> Thanks
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
