[Mapserver-users] Mapserver using MSSQL
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue Jun 1 07:52:39 EDT 2004
Kalpin Erlangga Silaen schrieb:
> Dear all,
> 1. While I try use ogrinfo I get error like this :
> D:\openev_fw\bin>ogrinfo layer1.ovf
> FAILURE:
> Unable to open datasource `layer1.ovf' with the following drivers.
> -> ESRI Shapefile
> -> UK .NTF
> -> SDTS
> -> TIGER
> -> IHO S-57 (ENC)
> -> MapInfo File
> -> DGN
> -> GML
> -> AVCBin
> -> OGDI
in your version of OGR ODBC is missing. This version seem not to be
compiled with ODBC support. So you have to get another version of OGR.
Regards,
Norbert
> D:\openev_fw\bin>
> 2. I am using Mapserver version 4.2 beta2 (ms42b2_gif_pg.zip)
> 3. Yes, I am using System DSN to create ODBC connection.
> I have try change LAYER_1 to another one like KAMPUN_1 and still same error.
> I am still need your help.
> Thank you
> ----- Original Message -----
> From: <bartvde at xs4all.nl>
> To: "Kalpin Erlangga Silaen" <kalpin at solonet.co.id>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Tuesday, June 01, 2004 5:27 PM
> Subject: Re: [Mapserver-users] Mapserver using MSSQL
>>Hi,
>>1. can ogrinfo read the ovf file successfully?
>>2. which version of Mapserver are you using (try 4.2 beta3 from
>>http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html).
>>3. are you using a System DSN?
>>One thing which is incorrect for sure but I don't know if this is fatal,
>>your <LayerSRS>LAYER_1</LayerSRS>. You can probably use your EPSG code for
>>this.
>>Best regards,
>>Bart
>>>Dear all,
>>>Today, I am trying run MapServer under windows using MSSQL 2000. I have
>>>read previous thread/mails and try to follow every step but I got error
>>>like below :
>>>msDrawMap(): Image handling error. Failed to draw layer named 'LAYER_1'.
>>>msOGRFileOpen(): OGR error. Open failed for OGR connection `layer1.ovf'.
>>>File not found or unsupported format.
>>>My Layer code :
>>>LAYER
>>> NAME LAYER_1
>>> TYPE POLYGON
>>> STATUS DEFAULT
>>> CONNECTIONTYPE OGR
>>> CONNECTION "layer1.ovf"
>>> DATA "layer1"
>>> CLASS
>>> NAME 'My City'
>>> OUTLINECOLOR 128 128 128
>>> COLOR 225 225 185
>>> TEMPLATE "layer1.html"
>>> END
>>> HEADER "layer_1_header.html"
>>> FOOTER "layer_1_footer.html"
>>> METADATA
>>> WMS_TITLE "My City"
>>> WMS_ABSTRACT "Layer Shapefile."
>>> WMS_SRS "EPSG:26915"
>>> END
>>>END
>>>and my layer1.ovf :
>>><OGRVRTDataSource>
>>> <OGRVRTLayer name="LAYER_1">
>>> <SrcDataSource>ODBC:sa/kalpin at mstest</SrcDataSource>
>>> <SrcLayer>River</SrcLayer>
>>> <GeometryType>wkbPoint</GeometryType>
>>> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
>>> </OGRVRTLayer>
>>></OGRVRTDataSource>
>>>Help me please
>>>Thank you
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
