[Mapserver-users] bug postgis query alias
strk
strk at keybit.net
Tue Jun 1 08:23:54 EDT 2004
On Tue, Jun 01, 2004 at 07:08:59AM -0500, Vladimir Guzmán wrote:
> The line 33 is just the draw method:
> $mapa = $map->draw();
That tells me nothing...
I'm afraid the bug is in php-mapscript or mapserver itself.
--strk;
> Vladimir Ilich Guzmán R.
> http://maintask.com
> strk wrote:
> >On Tue, Jun 01, 2004 at 06:56:45AM -0500, Vladimir Guzmán wrote:
> >>Yes, the query runs fine in the pgsql monitor:
> >>gps=> select gid,'>' as sentido,tiempo,360-rumbo+90 as
> >>rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-31
> >>05:00:00' and tiempo<='2004-06-02 04:59:59';
> >>gid | sentido | tiempo | rumbo | velocidad |
> >>gps_geom | oid
> >>46275 | > | 2004-05-31 15:16:09 | 450 | 0 |
> >>SRID=1;POINT(-74.06318 4.67302) | 7731018
> >>46276 | > | 2004-05-31 15:16:15 | 450 | 0 |
> >>SRID=1;POINT(-74.06318 4.67302) | 7731019
> >>46277 | > | 2004-05-31 15:16:21 | 450 | 0 |
> >>SRID=1;POINT(-74.06319 4.67301) | 7731020
> >>The error is just:
> >>*Warning*: MapServer Error in msDrawMap(): Failed to draw layer named
> >>'puntosgps'.
> >>in */usr/local/apache/htdocs/gps/index.phtml* on line *33*
> >Ooh.. I see.. php involved!
> >There are lot's of auto handling of special chars with php...
> >Showing that line '33' would also be useful.
> >--strk;
> >>http://maintask.com
> >>strk wrote:
> >>>On Mon, May 31, 2004 at 03:29:45PM -0500, Vladimir Guzmán wrote:
> >>>>Hello.
> >>>>I'm implementing a gps tracking system.
> >>>>I want to show the car's orientation like this:
> >>>>http://maintask.com/test.png
> >>>>The layer's data is something like this:
> >>>>gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
> >>>>rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-29
> >>>>05:00:00' and tiempo<='2004-05-30 04:59:59') as foo using unique gid
> >>>>using srid=1
> >>>>The field 'sentido' contains '>'.
> >>>>The problem is that if I use something like this:
> >>>>gps_geom from (select gid,'>' as sentido,tiempo,360-rumbo+90 as
> >>>>using srid=1
> >>>>The query doesn't work.
> >>>>So I had to create a column in potgres called 'sentido' and all the
> >>>>rows containing '>'.
> >>>>Is this a bug?
> >>>What's the error message ?
> >>>Can you run the query from the pgsql monitor ?
> >>>--strk;
> >>>>The rest of the layer:
> >>>>LAYER
> >>>>NAME "puntosgps"
> >>>>CONNECTIONTYPE postgis
> >>>>CONNECTION "user=gps password=gps dbname=gps host=localhost"
> >>>>DATA "gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
> >>>>using srid=1"
> >>>>TYPE POINT
> >>>>PROJECTION
> >>>>"proj=latlong"
> >>>>"datum=WGS84"
> >>>>END
> >>>>LABELANGLEITEM 'rumbo'
> >>>>LABELITEM 'sentido'
> >>>>CLASS
> >>>>NAME 'Parado'
> >>>>EXPRESSION ([velocidad] = 0)
> >>>>SIZE 14
> >>>>SYMBOL 'circle'
> >>>>COLOR 0 0 215
> >>>>OUTLINECOLOR 204 204 204
> >>>>END
> >>>>CLASS
> >>>>NAME '0-10'
> >>>>EXPRESSION ([velocidad] > 0 AND[velocidad] <= 10)
> >>>>SIZE 14
> >>>>SYMBOL 'circle'
> >>>>COLOR 255 255 204
> >>>>LABEL
> >>>> TYPE TRUETYPE
> >>>> FORCE TRUE
> >>>> FONT arial
> >>>> ANTIALIAS TRUE
> >>>> COLOR 0 0 0
> >>>> OUTLINECOLOR 255 255 255
> >>>> SIZE 8
> >>>>END
> >>>>END
> >>>>Thanks a lot.
> >>>>http://maintask.com
> >>>>_______________________________________________
> >>>>Mapserver-users mailing list
> >>>>Mapserver-users at lists.gis.umn.edu
> >>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
