[Mapserver-users] virtual spatial data-ODBC:configuration-windows
Zak James
zak-ms at hoppsan.org
Tue Jun 1 13:03:45 EDT 2004
Jenu,
Good news! Consider adding your experiences in using the virtual driver
under windows to the wiki page:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
so that others can benefit.
Frank Warmerdam recently added code to the mapserver CVS to report the
CPLGetLastErrorMsg() if OGR Open fails; once that is available in
windows builds, it should make it easier to determine what is going
wrong with failing virtual driver connections.
zak
On May 28, 2004, at 3:44 PM, Jenu Abraham wrote:
> Hey guys (chip, joost, zac)
> Got the problem fixed....
> Its simple...
> when setting up the ODBC for the system DSN
> In the window where it asks which type of authentication- > go for the
> with SQL server instead of Windows NT
> next rember to check the Connect SQL servere to obtain default
> settings and enter the username and password
> the problem was ogrinfo was working still with windowsNT
> authentication and with SQL server without obtaining the default
> settings... But mapserver.exe wont work with those settings...
> even though i havnt been able to plot a point on my map... atleast the
> connection problem is over for now....
> thanks
> cheers
> jenu
> _________________________________________________________________
> FREE pop-up blocking with the new MSN Toolbar get it now!
> http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
