[Mapserver-users] problems with curl
Sean Gillies
sgillies at frii.com
Wed Jun 2 11:52:55 EDT 2004
On Jun 2, 2004, at 9:37 AM, Lars Möller wrote:
> hi,
> I have a problem with make.
> I start with this configure:
> ../configure --with-proj=/usr/local/
> --with-gdal=/usr/local/bin/gdal-config
> --with-ogr=/usr/local/bin/gdal-config --disable-ignore-missing-data
> --with-wmsclient --with-wfsclient --with-ttf=/usr
Forget not to specify for curl
--with-curl-config=PATH
where PATH is like /usr/local/bin/curl-config
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
