[Mapserver-users] Virtual Spatial Data - projection
Doug Cates
doug at moximedia.com
Wed Jun 2 12:17:08 EDT 2004
Your coordinates have the x and y wrong. Chicago O'Hare airport is at:
lat/long 41.9795833 / -87.9044722
Which should appear in your table like:
x | y
-87.9044722 | 41.9795833
Doug
On Wed, 2004-06-02 at 08:48, Jenu Abraham wrote:
> still no points showing up on the map....
> this is how my table looks now
> table: latlong
> x | y
> 41.5 | -87.5
> 35.5 | -97.4
> >From: "Pagurek, Debbie" <PAGUREKD at AGR.GC.CA>
> >To: "Jenu Abraham" <jenu_ab at hotmail.com>,
> ><mapserver-users at lists.gis.umn.edu>
> >Subject: RE: [Mapserver-users] Virtual Spatial Data - projection
> >Date: Wed, 2 Jun 2004 10:06:54 -0400
> >You have the negative in the wrong place.
> >e.g. Chicago should be 41.5 -87.2
> >Debbie
> >-----Original Message-----
> >From: mapserver-users-admin at lists.gis.umn.edu
> >[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Jenu
> >Abraham
> >Sent: Tuesday, June 01, 2004 4:12 PM
> >To: mapserver-users at lists.gis.umn.edu
> >Subject: [Mapserver-users] Virtual Spatial Data - projection
> >guys...
> >i have been trying to plot points on a US map using latlong cordinates
> >from
> >my SQL table using virtual spatial data
> >ogrinfo gave the correct output..with testing2.ovf
> >eg: -35.5 97.4 oklahomaq city
> > -41.5 87.2 chicago
> >i can see the states layer but
> >i dont see any points on my map..from the truck layer
> >why? is something wrong in the projection
> >MAP
> > NAME e-test-rd-jbox-vsd_
> > IMAGETYPE GIF
> > EXTENT -2236857.50 -1744057.00 2786329.50 29069.36
> > SIZE 800 600
> > SHAPEPATH "C:\cgi-bin\data\"
> > FONTSET "C:\cgi-bin\fonts\fonts.list"
> > WEB
> > TEMPLATE 'e-test-rd-jbox.html'
> > IMAGEPATH 'C:\cgi-bin\tmp\'
> > IMAGEURL '/tmp/'
> > END
> > PROJECTION
> > "init=epsg:2163"
> > END
> > LAYER # States polygon layer begins here
> > NAME states
> > DATA statesp020
> > STATUS DEFAULT
> > TYPE POLYGON
> > PROJECTION
> > "init=epsg:4326"
> > END
> > CLASS
> > COLOR 240 240 100
> > END
> > END # States polygon layer ends here
> >LAYER # start of truck position from database
> > NAME trucks
> > TYPE POINT
> > CONNECTIONTYPE OGR
> > CONNECTION "testing2.ovf"
> > DATA "mylayer"
> > STATUS DEFAULT
> > PROJECTION
> > "proj=latlong"
> > END
> > CLASS
> > SYMBOL 1
> > SIZE 6
> > COLOR 255 0 0
> > END
> >END # end of connection layer
> ># End of LAYER DEFINITIONS
> >END # end of map file
> _________________________________________________________________
> FREE pop-up blocking with the new MSN Toolbar get it now!
> http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
