[Mapserver-users] Problem of configuration ? {Scanned}
Siki Zoltan
siki at agt.bme.hu
Wed Jun 2 14:03:37 PDT 2004
1. Check FONTSET in your map file, what file it is refering to
2. Check the FONT line in the label definition
FONT font_alias_name
3. Look for the font_alias_name in the font list file, and check
the full path given for that alias
probably you have to change the path
or you have not that font, replace the path to an existing font
Bye
Zoltan
On Wed, 2 Jun 2004, wilfried Heintz wrote:
> Hello,
> I'm using the MapServer 4.0 tutorial and I've got a problem in section 1
> example 1.4 (example 1.1, 1.2 and 1.3 work well)
> The error message is msGetLabelSize(): TrueType Font error. Could not
> find/open font
> I'm using MapServer 4.0.2 for Windows, on Windows XP with Apache server
> (easyphp).
> Thanks for your help.
> wilfried
> _______________________________________________________
> Wilfried Heintz
> Inventaire Forestier National - Cellule Evaluation de la Ressource
> Place des Arcades - Maurin
> BP 1001
> 34972 Lattes cedex
> Tel. +33 (0) 4 67 07 80 98
> Fax. +33 (0) 4 67 07 80 91
> > http://projet.sinpa.free.fr/
More information about the MapServer-users
