[Mapserver-users] Projection support is not available error
igor
ikezhis at gismo.com
Wed Jun 2 16:04:05 EDT 2004
Hello. I get the following error while trying to access mapserver
"Projection support is not available"
I used the --with-proj=/usr/local/lib option to point to the proj
library files. (Which I did compile and install). At first it complaned
that projects.h can not be found. So I manualy coped it to this
directory, after which it compiled with out any errors.
My system configuration is :
Suse 9.1
Apache 2.0.49
Map Server 4.0.1
Thanks for any help in advance.
