[Mapserver-users] GeoTiff output color problems
Matthew Perry
mtperry78 at sbcglobal.net
Wed Jun 2 18:20:20 EDT 2004
Frank,
Thanks for the reply.
I get the same strange colors when using IMAGEMODE
RGBA. We are using the following setup:
GDAL 1.1.9.0, released 2003/06/27
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
I noticed there is no OUTPUT=TIFF ??? Is this not
shown since it is handled by the GDAL libs?
Other than geotiff output, the setup works fine. I do
not have administrative privleges on this server so I
am not at liberty to experiment with 4.2. What would
you suggest for next steps... upgrade GDAL, upgrade
Mapserver, or both??
Thanks for your help!
- matt
--- Frank Warmerdam <warmerdam at pobox.com> wrote:
> Matthew Perry wrote:
> > Hello folks,
> > Testing a new intallation of mapserver here and
> I'm getting some wierd
> > results when outputting Geotiffs:
> > When I use the following:
> > OUTPUTFORMAT
> > NAME GTiff
> > DRIVER "GDAL/GTiff"
> > MIMETYPE "image/tiff"
> > IMAGEMODE PC256
> > EXTENSION "tif"
> > END
> > I get this image:
> http://ktrin.cnrs.humboldt.edu/misc/gtiff_256.tif
> > This has the correct colors but poor quality, plus
> I would like to have
> > 24 bit output. So I tried the following:
> Matthew,
> I'm not sure how you generated this. It should have
> the same colors
> that you would find if you did png output.
> > OUTPUTFORMAT
> > NAME GTiff
> > DRIVER "GDAL/GTiff"
> > IMAGEMODE RGB
> > EXTENSION "tif"
> > END
> > which gives me this image with bizzare colors (but
> better resolution):
> > http://ktrin.cnrs.humboldt.edu/misc/gtiff_rgb.tif
> > Both images are properly georeferenced, though. I
> have tried reversing
> > the order of the bands (in ArcMap 8.3) to no
> avail.
> > Any ideas why the Geotiff 24bit color would be
> innacurate?
> It looks like a color band mixup of some sort. The
> blue band seems to really
> be alpha values. Try IMAGEMODE RGBA and see if the
> result is any better.
> I would appreciate your submitting a bugzilla report
> about the RGB output if
> you can boil it down to something easy to reproduce
> with MapServer 4.2.
> PS. please assign the bug report directly to me.
> Best regards,
> I set the clouds in motion - turn up | Frank
> Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
