[Mapserver-users] problems with curl
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Jun 2 20:18:27 EDT 2004
Lars Möller wrote:
> hallo,
> thanks for your help, but
> with the spezified curl-config-path (which is correct)
> I get the same error.
> ./configure --with-proj=/usr/local/
> --with-gdal=/usr/local/bin/gdal-config
> --with-ogr=/usr/local/bin/gdal-config --disable-ignore-missing-data
> --with-wmsclient --with-wfsclient --with-ttf=/usr
> --with-curl-config=/usr/local/bin/curl-config
It's probably that you have another (older) copy of curl on your system
somewhere. If you are using a RedHat system then do you can find out if
the curl RPMs are installed using
rpm -qa | grep curl
If they are installed then you need to remove them. On other systems use
the appropriate tools to find out if curl was previously installed and
uninstall it.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
