[Mapserver-users] problems with curl
Lars Möller
moeller at basis5.de
Thu Jun 3 04:42:43 EDT 2004
ok. I removed the older copy of curl.
so there is no problem anymore.
thanks
Daniel Morissette schrieb:
> Lars Möller wrote:
>> hallo,
>> thanks for your help, but
>> with the spezified curl-config-path (which is correct)
>> I get the same error.
>> ./configure --with-proj=/usr/local/
>> --with-gdal=/usr/local/bin/gdal-config
>> --with-ogr=/usr/local/bin/gdal-config --disable-ignore-missing-data
>> --with-wmsclient --with-wfsclient --with-ttf=/usr
>> --with-curl-config=/usr/local/bin/curl-config
> It's probably that you have another (older) copy of curl on your system
> somewhere. If you are using a RedHat system then do you can find out if
> the curl RPMs are installed using
> rpm -qa | grep curl
> If they are installed then you need to remove them. On other systems use
> the appropriate tools to find out if curl was previously installed and
> uninstall it.
> Daniel
_____________________________
dipl.-ing. lars möller
basis5 - webtechnologie
möller und zipp ingenieure
und partner
malsburgstrasse 14
34119 kassel
tel 0561.7660348
fax 0561.7660358
email moeller at basis5.de
www.basis5.de
