[Mapserver-users] no tiff layer {Scanned}
Lars Möller
moeller at basis5.de
Thu Jun 3 08:46:12 EDT 2004
thanks for your answer.
I checked the landsat layer.
it gives an png format out. gdal supports png the mapserver too.
I see the mapserver supports only output png but input gdal. gdal
supports png.
the only thing I didn't get installed is the libXpm.
I don't find a way to installe this.
could that be the reason?
the output of mapserv -v gdalinfo --formats and configure follows:
configure: checking where libXpm is installed......
checking for XpmFreeXpmImage in -lXpm... no
XPM (libXpm) library cannot be found, possibly needed for GD
the mapserver gives this out:
msDrawMap(): Image handling error. Failed to draw layer named 'landsat'.
msDrawRaster(): Image handling error. Unrecognized or unsupported image
format
drawEPP(): Image handling error.
/usr/local/httpd/htdocs/tmp/108626019873110.img.tmp is not an EPPL file.
this is was in landsat layer stnads:
LAYER # LandSat WMS map from JPL
NAME landsat
TYPE RASTER
OFFSITE 0 0 0
STATUS OFF
CONNECTIONTYPE WMS
CONNECTION
"http://wms.jpl.nasa.gov/wms.cgi?REQUEST=map&LAYERS=us_landsat7&STYLES=&FORMAT=png&TRANSPARENT=true"
METADATA
"wms_title" "US Landsat7 image mosaic"
"wms_name" "us_landsat7"
"wms_abstract" "Seamless mosaic of Landsat7 1999/2000. 1/2
arcsecond, pansharpened"
"wms_server_version" "1.0.0"
"wms_srs" "epsg:4326"
"wms_format" "image/png"
END
PROJECTION
"init=epsg:4326"
END
END # LandSat WMS image ends here
this gives the mapserv -v :
MapServer version 4.0.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
the gdalinfo --formats:
Supported Formats:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
SAR_CEOS: CEOS SAR Image
CEOS: CEOS Image
ELAS: ELAS
AIG: Arc/Info Binary Grid
AAIGrid: Arc/Info ASCII Grid
SDTS: SDTS Raster
DTED: DTED Elevation Raster
PNG: Portable Network Graphics
JPEG: JPEG JFIF
MEM: In Memory Raster
JDEM: Japanese DEM (.mem)
GIF: Graphics Interchange Format (.gif)
ESAT: Envisat Image Format
BSB: Maptech BSB Nautical Charts
XPM: X11 PixMap Format
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
PNM: Portable Pixmap Format (netpbm)
DOQ1: USGS DOQ (Old Style)
DOQ2: USGS DOQ (New Style)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Atlantis MFF Raster
MFF2: Atlantis MFF2 (HKV) Raster
FujiBAS: Fuji BAS Scanner Image
GSC: GSC Geogrid
FAST: EOSAT FAST Format
BT: VTP .bt (Binary Terrain) 1.3 Format
JPEG2000: JPEG-2000 part 1 (ISO/IEC 15444-1)
L1B: NOAA Polar Orbiter Level 1b Data Set
FIT: FIT Image
USGSDEM: USGS Optional ASCII DEM
GXF: GeoSoft Grid Exchange Format
Siki Zoltan schrieb:
> Hi,
> Propably the raster format of landsat not supported on your installed
> version.
> Check
> mapserv -v
> or
> gdalinfo --format
> to see the supported raster formats, it depends on your installation.
> Bye Zoltan
> On Thu, 3 Jun 2004, [ISO-8859-1] Lars Möller wrote:
>>hi,
>>I tried the example3-3.htm with the layer landsat.
>>I get this error:
>>format
>>/usr/local/httpd/htdocs/tmp/108625921164530.img.tmp is not an EPPL file.
>>whenn I configure I get this error:
>>could the missing libXpm bring the error?
>>I tried to installe this libXpm, but dosen't work.
>>has somenone an idea?
>>thanks lars möller
>>_____________________________
>>dipl.-ing. lars möller
>>basis5 - webtechnologie
>>möller und zipp ingenieure
>>und partner
>>malsburgstrasse 14
>>34119 kassel
>>tel 0561.7660348
>>fax 0561.7660358
>>email moeller at basis5.de
>>www.basis5.de
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
und partner
malsburgstrasse 14
34119 kassel
tel 0561.7660348
fax 0561.7660358
www.basis5.de
