[mapserver-users] querying WMS layer / WFS reprise
Frank Warmerdam
warmerdam at pobox.com
Thu Jun 3 11:31:31 EDT 2004
Gregor Mosheh wrote:
> I spent the last day experimenting with WFS, since that's what we *really*
> want to be sending instead of images, and came to the conclusion (that
> seems to have been confirmed by some others on the list) that WFS is
> incredibly slow (as in, several minutes) because of the GML encoding,
> which made it unsuitable for use in dynamic map layers.
> WFS' slowness surprised me: should a feature list being sent to the client
> never contain more than several items? Or is this a "problem" with
> MapServer's implementation of a WFS server? Would another WFS server
> (GeoServer?) do it faster and be able to send more items in a reasonable
> period?
Gregor,
I don't think WFS queries should be inherently slow. Encoding GML is not
a particularly expensive task. But there are lots of issues to be careful
of with WFS. For instance, it is easy to unexpectedly generate a very large
GML response set if you select alot of features or they are very complex.
I think you need to examine what you are doing more closely to see if:
o the resultset is very large (dump response to file and inspect size)
o the query being done by MapServer is expensive. Some WFS geometric
queries may be expensive to check. MapServer is generally not terribly
fast at attribute queries as far as I know.
o The MapServer query architecture requires that each query result be
fetched individually by id after a first pass to build a list of ids for
features that satisfy the request. This kind of read is very slow
against some datasources (ie. some OGR drivers).
Lets try and dig into the performance a bit deeper to determine what the
issue is.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
