[Mapserver-users] What is CONFIG parameter for?
Tyler Mitchell
TMitchell at lignum.com
Thu Jun 3 15:45:49 PDT 2004
I've used it to setup GDAL_DATA to point to my gdal/data folder (for S57
format this is required). In essence, it appears to be useful for time
when you need set environment variables (or just a couple specific ones?)
that mapserv or dependents will be looking for. I haven't tried it for
PROJ yet, but that too will (should ?) solve some path problems that have
previously relied on setting global environment variables which may not be
an option on non-sysadmin accounts.
That's my observations anyway. Good stuff!
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 06/03/2004 04:39:05 PM:
> I've seen in Mapserver 4.2 docs the new CONFIG parameter that was
> added for MAP object...
> what is the main goal of it? to avoid re-compilation of MapServer
> for diferrents applications?
> I saw it handles GDAL and PROJ options... what more can be done?
> thanks
> Eduardo Patto Kanegae
> http://www.consultoria.eti.br
> UIN: 303747254
> I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.
> univali.br/encontro2004
> Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
> ***Fim da Mensagem / End of Message ***
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
