[Mapserver-users] projection issues
Jeff Hoffmann
jeff at propertykey.com
Fri Jun 4 10:21:12 EDT 2004
Leah Roderman wrote:
> I always tangle with projection issues and then forget my solutions.
> Problem: My coordinates are misaligned with my TIGER shapefiles.
> The long explanation: I am using TIGER '90 polygons and line features.
> Atop these, I am displaying points used by taking GPS readings, saving
> them in Postgres, and retrieving them via PostGIS.
> I am collecting GPS data using a Garmin etrex Vista. The export file I
> generate for coordinates includes "Datum WGS 84" at top. My
> understanding of TIGER is that it is not in any projection (based on
> http://www.census.gov/geo/www/tlmetadata/metadata.html).
I use EPSG 4269 for newer TIGER which seems to work fine. I haven't
used older TIGER, but since they say they use NAD27 pre-1994, I'd guess
you'd want to use EPSG 4267. I don't know about the GPS coordinates,
although I would start by trying EPSG 4326.
Jeff Hoffmann
PropertyKey.com
