[Mapserver-users] Perl/MapScript or PHP/Mapscript
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Fri Jun 4 12:56:49 EDT 2004
Hi Sean,
I saw your draw below...
what is SWIG? is it a what of "framework" that Python, Ruby and Perl makes use to deploy MapScript?
http://www.consultoria.eti.br
UIN: 303747254
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
***Fim da Mensagem / End of Message ***
On Fri, 4 Jun 2004 09:05:43 -0600, Sean Gillies <sgillies at frii.com> escreveu:
> De: Sean Gillies <sgillies at frii.com>
> Data: Fri, 4 Jun 2004 09:05:43 -0600
> Para: Alexander Lim <alexanderlimkh at yahoo.com>
> Assunto: Re: [Mapserver-users] Perl/MapScript or PHP/Mapscript
> On Jun 3, 2004, at 11:44 PM, Alexander Lim wrote:
> > Hi all,
> > I just getting started and realised that we can make
> > use of Perl/MapScript and PHP/Mapscript, but i would
> > like to know what's the differences and which one is
> > "better" to use. And which one is more popular and
> > more people are using it (This is for getting help
> > from this list when i face some problem down the
> > line). Does the two perform and is doing the same
> > thing at all?
> > which one should i adopt in terms of flexibility and
> > features.
> > please advice. thanks
> > alex
> Hi Alex,
> The mapscript family tree looks like this:
> MapServer
> PHP/MapScript \
> \ SWIG MapScript
> Perl Python Ruby
> The Perl, Python, Ruby flavors are like brothers and sisters and
> the PHP MapScript is like a very close cousin to them.
> They are all quite equal in mapping capability. The Perl mapscript
> does not quite work natively on Windows, but the others work equally
> well across platforms.
> There is no clear "better" choice. It will depend on your needs.
> The PHP language makes web programming easy, and this is the most
> popular type of MapScript. The DM Solutions Group uses PHP/Mapscript
> primarily and have developed a bunch of great web mapping tools that
> they share with PHP/Mapscript users.
> http://maptools.org/
> They are also very good about answering questions on the users list, so
> PHP/Mapscript has the best overall support. One looming issue for
> PHP/Mapscript is that there is currently no support for PHP 5.
> On the other hand: Perl, Python, and Ruby are better and more complete
> programming languages than PHP. Each of these languages are great for
> web programming. The Ruby flavor of mapscript is very new, and is
> being used in an application called MapDesk:
> http://www.sourcepole.com/mapdesk/
> The Perl flavor of mapscript has been widely used, but isn't showing
> much promise as a basis for apps like MapDesk. I don't understand
> why.
> The Python flavor of mapscript is now the best supported of the
> Perl/Python/Ruby family. In my opinion, the strongest argument for
> using Python/MapScript is that you can then also use the GDAL module
> for Python. This gives you the best access to many raster and
> vector data formats. If you are a windows user, you can download a
> windows installer for Python Mapscript from
> http://users.frii.com/sgillies/projects/pymapscriptwin32.zip
> It works right "out of the box" and batteries are included.
> Hope this information helps you. There are more options than you may
> have expected!
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
