[Mapserver-users] functions to parse a map file?
Vladimir Guzmán
bigfoot at main-task.com
Fri Jun 4 17:14:03 EDT 2004
Mark:
If you're using PHP Mapscript, you can access the layer's information
using something like this:
for($i=0;$i< $map->numlayers;$i++){
$layer=$map->getLayer($i);
print_r($layer);
Hope that helps,
Vladimir Ilich Guzmán R.
http://maintask.com
Mark Adams wrote:
> Hi all,
> We are developing a sample site with Mapserver 4.2 and PHP mapscript.
> Wed like to add some custom functions that require that we can
> determine at run time certain aspects of the layers being published
> through the map file, for example what type of data the layer is (e.g.
> raster, shapefile), what its geometry type is (e.g. polygon, line),
> etc. We had been thinking wed parse the map file on initial load, and
> access it programmatically from a set of arrays; but as the map file
> structure is not XML based there isnt an easy way of parsing the map
> file directly. Are there any built-in functions available to allow us
> to do this?
> Thanks for any help you can provide.
> Mark Adams
> Business & Systems Analyst
> Cuesta Systems Inc.
> 5230 South Service Road
> Burlington, ON L7L 5K2
> Phone: 905-333-4544 x14
> Fax: 905-333-0455
> Email: markadams at cuestasys.com
