[Mapserver-users] Blank or no image returned
Andrew Rich
devel at itdownunder.com.au
Fri Jun 4 19:10:54 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_000C_01C44ADD.03542310
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi All
I have Mapserv 4.2 installed and works with Itasca demo.
I am now modifying the Itasca demo and using a image of the world in
TOPO8.TIF
Tyler has given me a .map file which I am adjusting to the paths of my
mapserv server.
When loading the Initialize file the renamed Itasca demo for shows then
select the basic application. The normal Itasca screen shows but the
box is just the color set in IMAGECOLOR 100 100 255. It was 255 255 255
which was white but I changed to this blue for testing.
The scale bar in the lower left corner is in Kilometres and adjusts on
Zoom In and Out.
I have included a lot of information below but I need assistance to move
on I think.
I saw in a previous post that it may be related to the projection but my
knowledge of these topics is very limited.
Thank you for any assistance.
Andrew Rich
Maps Downunder
==== mapserv40 -v ====
MapServer version 4.2.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
==== ldd /var/www/cgi-bin/mapserv40 ====
libgd.so.2 => /usr/local/lib/libgd.so.2 (0x4002b000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40064000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40082000)
libpng.so.3 => /usr/local/lib/libpng.so.3 (0x400c1000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x400ee000)
libgdal.so.1 => /usr/local/lib/libgdal.so.1 (0x40121000)
libcurl.so.3 => /usr/local/lib/libcurl.so.3 (0x40417000)
libdl.so.2 => /lib/libdl.so.2 (0x40444000)
libm.so.6 => /lib/i686/libm.so.6 (0x40447000)
libc.so.6 => /lib/i686/libc.so.6 (0x42000000)
libpthread.so.0 => /lib/i686/libpthread.so.0 (0x40469000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x4047d000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x4048b000)
libpng12.so.0 => /usr/local/lib/libpng12.so.0 (0x40561000)
libz.so.1 => /usr/lib/libz.so.1 (0x4058e000)
libodbc.so.1 => /usr/lib/libodbc.so.1 (0x4059c000)
libungif.so.4 => /usr/lib/libungif.so.4 (0x405f9000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x40601000)
libssl.so.2 => /lib/libssl.so.2 (0x40644000)
libcrypto.so.2 => /lib/libcrypto.so.2 (0x40672000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
==== /etc/ld.so.conf ====
/usr/kerberos/lib
/usr/X11R6/lib
/usr/lib/qt2/lib
/usr/lib/mysql
/usr/lib/qt-3.0.5/lib
/usr/lib/sane
/usr/local/lib
/usr/lib/python1.5/site-packages
==== MAP FILE ====
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 400
EXTENT -180 -90 180 90 # Whole world
UNITS DD
SHAPEPATH "data"
#FONTSET "/usr/src/mapserver-4.2.0/tests/fonts.txt"
CONFIG GDAL_DATA "data"
IMAGETYPE PNG
# OUTPUTFORMAT
# NAME "gif"
# MIMETYPE "image/gif"
# DRIVER "GD/GIF"
# EXTENSION "gif"
# IMAGEMODE PC256
# TRANSPARENT FALSE
# END
# Projection definition, consult the PROJ.4 documentation for parameter
discussi
PROJECTION
"init=epsg:4326"
END
# Start of web interface definition
WEB
#HEADER demo_header.html
TEMPLATE giofinder_basic.html
#FOOTER demo_footer.html
IMAGEPATH "/var/www/html/maps/giofinder/tmp"
IMAGEURL "/giofinder/tmp/"
END
# Start of reference map
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 400
UNITS DD
SHAPEPATH "data"
IMAGETYPE PNG
# OUTPUTFORMAT
# NAME "gif"
# DRIVER "GD/GIF"
# EXTENSION "gif"
# IMAGEMODE PC256
# TRANSPARENT FALSE
# END
discussi
PROJECTION
"init=epsg:4326"
END
WEB
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE small
END
STYLE 1
SIZE 250 4
COLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
TRANSPARENT FALSE
STATUS TRUE
END
# Start of symbol definitions
SYMBOL
NAME 'circle'
TYPE ellipse
FILLED TRUE
POINTS 1 1 END
END
# Start of layer definitions
########## RASTER ##############
LAYER
NAME topo8
TYPE RASTER
DATA topo8.tif
STATUS OFF
PROJECTION
"proj=latlong"
"ellps=WGS84" # Geographic
END
END
END # Map File
==== INITIALIZE FILE ====
<html>
<head>
<title>Maps Downunder GioFinder Application</title>
<script language="javascript">
function submit_form() {
var template =
document.demo.map_web_template.options[document.demo.map_web_template.se
lectedIndex].value;
if(template.indexOf("frame") != -1) document.demo.action =
"frames.html";
if(template.indexOf("dhtml") != -1) document.demo.action =
"frames_dhtml.html";
<html>
<head>
var template =
lectedIndex].value;
"frames.html";
</script>
var template =
lectedIndex].value;
"frames.html";
</script>
</head>
<body bgcolor="#FFFFFF">
<center><h2>Maps Downunder GioFinder Application</h2></center>
<p><hr><p>
This demonstration application will take you through various levels
of complexity. Starting with a basic application that
allows a user to pan/zoom and change layers we add:
<ul>
<li> dynamically configured scalebars
<li> javascript-based panning
<li> query results to a frame
<li> and finally, a DHTML rubber-band zoom/query capabilty
</ul>
<!-- EDIT THE FORM ACTION -->
<form name="demo" method="GET" action="/cgi-bin/mapserv40"
onSubmit="submit_form()">
<input type="hidden" name="layer" value="contours">
<input type="hidden" name="layer" value="dlgstln2">
<input type="hidden" name="zoomsize" value=2>
<!-- EDIT THESE HIDDEN VARIABLES -->
<input type="hidden" name="map"
value="/var/www/html/maps/giofinder/world.map">
<input type="hidden" name="program" value="/cgi-bin/mapserv40">
<input type="hidden" name="root" value="/giofinder">
<input type="hidden" name="map_web_imagepath"
value="/var/www/html/maps/giofinder/tmp/">
<input type="hidden" name="map_web_imageurl"
value="/giofinder/tmp/">
<select name="map_web_template" size="1">
<option value="giofinder_basic.html"> Basic Application
<option value="giofinder_adds_scalebar.html"> --
Adds second scalebar
<option value="giofinder_adds_pan.html"> -- Adds pan
controls
<option value="giofinder_adds_frames.html"> -- Adds
frames
<option value="giofinder_adds_dhtml.html"> -- Adds
dhtml rubber-band box
</select>
<input type="submit" value="Initialize"></center>
</form>
<p><hr><p>
</body>
</html>
==== TEMPLATE HTML ====
<html>
<head>
var template =
lectedIndex].value;
"frames.html";
<html>
<head>
var template =
lectedIndex].value;
"frames.html";
</script>
var template =
lectedIndex].value;
"frames.html";
</script>
<html>
<head>
<html>
<head>
<title>Maps Downunder - GioFinder Application</title>
</head>
<body bgcolor="#ffffff">
<center><h1>Maps Downunder - GioFinder Application</h1></center>
<hr>
<form method="GET" action="[program]" name="mapserv">
<center>
<table border="0" cellspacing="0" cellpadding="4">
<tr>
<td valign="top" align="center">
<table width="390" border="0" cellspacing="0" cellpadding="4"
align="center" bgcolor="#666666">
<tr>
<td align="center"><input type="image" name="img" src="[img]"
width="[mapwidth]" height="[mapheight]" border="0" alt="this is the
map"></td>
</tr>
<tr><td bgcolor="#666666">
<img title="scalebar (mi)" alt="scalebar (mi)" src="[scalebar]">
</td></tr>
</table>
</td>
<td valign="top" bgcolor="#ffffff">
<table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
<tr><td>
<center><input type="submit" value="Refresh/Query"></center>
<p>
<input type="radio" name="mode" value="browse" checked> <b>Browse
map</b><br>
<input type="radio" name="mode" value="query"> <b>Query
feature</b><br>
<input type="radio" name="mode" value="nquery"> <b>Query multiple
features</b>
<hr>
<p>
<b>Select Layers to Display: </b><br>
<select multiple name="layer" size=3>
<option value="contours" [contours_select]> Contours
<option value="waterbodies" [waterbodies_select]> Lakes & Rivers
<!-- <option value="lakespy2" [lakespy2_select]> Lakes & Rivers
<option value="dlgstln2" [dlgstln2_select]> Streams
<option value="roads" [roads_select]> Roads
<option value="twprgpy3" [twprgpy3_select]> Townships
<option value="drgs" [drgs_select]> USGS 1:250,000 Quads
</select>
<p>
Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
Zoom Out <input type=radio name=zoomdir value=-1
[zoomdir_-1_check]>
<p>
Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
<p>
<font size=+1><b>Legend</b></font><br><hr>
<img src="[legend]"><hr>
<p>
<center><input name="ref" type="image" src="[ref]"
border="0"></center>
</td></tr></table>
</td></tr>
</table>
</center>
<input type="hidden" name="imgxy" value="[center]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="root" value="[root]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="program" value="[program]">
value="[map_web_imagepath]">
<input type="hidden" name="map_web_imageurl" value="[map_web_imageurl]">
<input type="hidden" name="map_web_template" value="[map_web_template]">
</form>
<p><hr><p>
<a href="[root]/index.html">back to start</a><p>
<i>[map_web_template]</i>
</body></html>
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44ADD.00751F00">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"City"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi All<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I have <span class=3DSpellE>Mapserv</span> 4.2 =
installed and
works with </span></font><st1:place><font size=3D2 face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Itasca</span></font></st1:pl=
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> =
demo.<o:p></o:p></span></font></p>
font-family:Arial'>I am now modifying the </span></font><st1:place><font
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> demo and
using a image of the world in TOPO8.TIF<o:p></o:p></span></font></p>
<p class=3DMsoNormal><st1:City><st1:place><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Tyler</span></font></st1:pla=
ce></st1:City><font
style=3D'font-size:10.0pt;font-family:Arial'> has given
me a .map file which I am adjusting to the paths of my <span =
class=3DSpellE>mapserv</span>
server.<o:p></o:p></span></font></p>
font-family:Arial'>When loading the Initialize file the renamed =
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> demo for
shows then select the basic application. <span
style=3D'mso-spacerun:yes'> </span>The normal =
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> screen
shows but the box is just the color set in IMAGECOLOR 100 <span =
class=3DSpellE>100</span>
255.<span style=3D'mso-spacerun:yes'> </span>It was 255 <span =
class=3DSpellE>255</span>
<span class=3DSpellE>255</span> which was white but I changed to this =
blue for
testing.<o:p></o:p></span></font></p>
font-family:Arial'>The scale bar in the lower left corner is in <span
class=3DSpellE>Kilometres</span> and adjusts on Zoom In and <span =
class=3DGramE>Out</span>.<o:p></o:p></span></font></p>
font-family:Arial'>I have included a lot of information below but I need
assistance to move on I think.<span style=3D'mso-spacerun:yes'> =
</span><o:p></o:p></span></font></p>
font-family:Arial'>I saw in a previous post that it may be related to =
the
projection but my knowledge of these topics is very limited. =
font-family:Arial'>Thank you for any =
assistance.<o:p></o:p></span></font></p>
font-family:Arial'>Andrew Rich<o:p></o:p></span></font></p>
font-family:Arial'>Maps Downunder<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D mapserv40 –v =
=3D=3D=3D=3D<o:p></o:p></span></font></p>
<p class=3DMsoNormal><span class=3DSpellE><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>MapServer</span></font></spa=
n><font
style=3D'font-size:10.0pt;font-family:Arial'> version
4.2.0 OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWBMP SUPPORTS=3DPROJ =
SUPPORTS=3DFREETYPE
SUPPORTS=3DWMS_SERVER SUPPORTS=3DWMS_CLIENT SUPPORTS=3DWFS_SERVER =
SUPPORTS=3DWFS_CLIENT
INPUT=3DEPPL7 INPUT=3DOGR INPUT=3DGDAL =
INPUT=3DSHAPEFILE<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D<span class=3DGramE>=3D <span
style=3D'mso-spacerun:yes'> </span><span =
class=3DSpellE>ldd</span></span>
/var/www/cgi-bin/mapserv40 =3D=3D=3D=3D<o:p></o:p></span></font></p>
font-family:Arial'><span
</span>libgd.so.2 =3D> /usr/local/lib/libgd.so.2 =
(0x4002b000)<o:p></o:p></span></font></p>
</span>libjpeg.so.62 =3D> /usr/lib/libjpeg.so.62 =
(0x40064000)<o:p></o:p></span></font></p>
</span>libfreetype.so.6 =3D> /usr/lib/libfreetype.so.6 =
(0x40082000)<o:p></o:p></span></font></p>
</span>libpng.so.3
=3D> /usr/local/lib/libpng.so.3 =
(0x400c1000)<o:p></o:p></span></font></p>
</span>libproj.so.0 =3D> /usr/local/lib/libproj.so.0 =
(0x400ee000)<o:p></o:p></span></font></p>
</span>libgdal.so.1 =3D> /usr/local/lib/libgdal.so.1 =
(0x40121000)<o:p></o:p></span></font></p>
</span>libcurl.so.3 =3D> /usr/local/lib/libcurl.so.3 =
(0x40417000)<o:p></o:p></span></font></p>
</span>libdl.so.2
=3D> /lib/libdl.so.2 (0x40444000)<o:p></o:p></span></font></p>
</span>libm.so.6 =3D> /lib/i686/libm.so.6 =
(0x40447000)<o:p></o:p></span></font></p>
</span>libc.so.6 =3D> /lib/i686/libc.so.6 =
(0x42000000)<o:p></o:p></span></font></p>
</span>libpthread.so.0 =3D> /lib/i686/libpthread.so.0 =
(0x40469000)<o:p></o:p></span></font></p>
</span>libXpm.so.4 =3D> /usr/X11R6/lib/libXpm.so.4 =
(0x4047d000)<o:p></o:p></span></font></p>
</span>libX11.so.6 =3D> /usr/X11R6/lib/libX11.so.6 =
(0x4048b000)<o:p></o:p></span></font></p>
</span>libpng12.so.0 =3D> /usr/local/lib/libpng12.so.0 =
(0x40561000)<o:p></o:p></span></font></p>
</span>libz.so.1 =3D> /usr/lib/libz.so.1 =
(0x4058e000)<o:p></o:p></span></font></p>
</span>libodbc.so.1 =3D> /usr/lib/libodbc.so.1 =
(0x4059c000)<o:p></o:p></span></font></p>
</span>libungif.so.4 =3D> /usr/lib/libungif.so.4 =
(0x405f9000)<o:p></o:p></span></font></p>
</span><span
class=3DGramE>libstdc</span>++-libc6.2-2.so.3 =3D>
/usr/lib/libstdc++-libc6.2-2.so.3 =
(0x40601000)<o:p></o:p></span></font></p>
</span>libssl.so.2 =3D> /lib/libssl.so.2 =
(0x40644000)<o:p></o:p></span></font></p>
</span>libcrypto.so.2 =3D> /lib/libcrypto.so.2 =
(0x40672000)<o:p></o:p></span></font></p>
</span>/lib/ld-linux.so.2 =3D> /lib/ld-linux.so.2 =
(0x40000000)<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D /etc/<span =
class=3DSpellE>ld.so.conf</span> =
font-family:Arial'>/<span =
class=3DSpellE>usr/kerberos/lib</span><o:p></o:p></span></font></p>
font-family:Arial'>/usr/X11R6/lib<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/qt2/lib<o:p></o:p></span></font></p>
class=3DSpellE>usr/lib/mysql</span><o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/qt-3.0.5/lib<o:p></o:p></span></font></p>
class=3DSpellE>usr</span>/lib/sane<o:p></o:p></span></font></p>
class=3DSpellE>usr</span>/local/lib<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/python1.5/site-packages<o:p></o:p></span></fo=
nt></p>
font-family:Arial'>=3D=3D=3D=3D MAP FILE =
font-family:Arial'>#<o:p></o:p></span></font></p>
font-family:Arial'># Start of map file<o:p></o:p></span></font></p>
font-family:Arial'>NAME DEMO<o:p></o:p></span></font></p>
font-family:Arial'>STATUS ON<o:p></o:p></span></font></p>
font-family:Arial'>SIZE 600 400<o:p></o:p></span></font></p>
font-family:Arial'>EXTENT -180 -90 180 <span class=3DGramE>90<span
style=3D'mso-spacerun:yes'> </span>#</span> Whole =
world<o:p></o:p></span></font></p>
font-family:Arial'>UNITS DD<o:p></o:p></span></font></p>
font-family:Arial'>SHAPEPATH =
"data"<o:p></o:p></span></font></p>
font-family:Arial'>IMAGECOLOR 100 <span class=3DSpellE>100</span> =
255<o:p></o:p></span></font></p>
font-family:Arial'>#FONTSET
"/usr/src/mapserver-4.2.0/tests/fonts.txt"<o:p></o:p></span></f=
ont></p>
font-family:Arial'>CONFIG GDAL_DATA =
font-family:Arial'>IMAGETYPE PNG<o:p></o:p></span></font></p>
<p class=3DMsoNormal><span class=3DGramE><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>#<span
</span>OUTPUTFORMAT</span></font></span><font
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span></font></p=
font-family:Arial'>#<span style=3D'mso-spacerun:yes'> </span><span
style=3D'mso-spacerun:yes'> </span>NAME =
"gif"<o:p></o:p></span></font></p>
</span>MIMETYPE "image/gif"<o:p></o:p></span></font></p>
</span>DRIVER "GD/GIF"<o:p></o:p></span></font></p>
</span>EXTENSION "gif"<o:p></o:p></span></font></p>
</span>IMAGEMODE PC256<o:p></o:p></span></font></p>
</span>TRANSPARENT FALSE<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'mso-spacerun:yes'> </span>END</span></font></span><font =
size=3D2
font-family:Arial'># Projection definition, consult the PROJ.4 =
documentation
for parameter <span =
class=3DSpellE>discussi</span><o:p></o:p></span></font></p>
font-family:Arial'>PROJECTION<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> =
</span>"<span
class=3DGramE>init=3D</span>epsg:4326"<o:p></o:p></span></font></p>
font-family:Arial'>END<o:p></o:p></span></font></p>
font-family:Arial'># Start of web interface =
definition<o:p></o:p></span></font></p>
font-family:Arial'>WEB<o:p></o:p></span></font></p>
</span>#HEADER
demo_header.html<o:p></o:p></span></font></p>
</span>TEMPLATE
giofinder_basic.html<o:p></o:p></span></font></p>
</span>#FOOTER
demo_footer.html<o:p></o:p></span></font></p>
</span>IMAGEPATH
"/<span =
class=3DSpellE>var/www/html/maps/giofinder/tmp</span>"<o:p></o:p></s=
pan></font></p>
</span>IMAGEURL
"/<span =
class=3DSpellE>giofinder/tmp</span>/"<o:p></o:p></span></font></p>
font-family:Arial'># Start of reference map<o:p></o:p></span></font></p>
font-family:Arial'># Start of legend<o:p></o:p></span></font></p>
font-family:Arial'>LEGEND<o:p></o:p></span></font></p>
</span>KEYSIZE 18 12<o:p></o:p></span></font></p>
</span>LABEL<o:p></o:p></span></font></p>
</span>TYPE BITMAP<o:p></o:p></span></font></p>
</span>SIZE MEDIUM<o:p></o:p></span></font></p>
</span>COLOR 0 <span class=3DSpellE>0</span> =
89<o:p></o:p></span></font></p>
</span>END<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>STATUS =
ont></p>
face=3DArial><span
</span>NAME "gif"<o:p></o:p></span></font></p>
face=3DArial><span
size=3D2
documentation
</span>"<span
</span>#HEADER
</span>TEMPLATE
</span>#FOOTER
</span>IMAGEPATH
"/<span =
pan></font></p>
</span>IMAGEURL
"/<span =
font-family:Arial'># Start of <span =
class=3DSpellE>scalebar</span><o:p></o:p></span></font></p>
font-family:Arial'>SCALEBAR<o:p></o:p></span></font></p>
</span>IMAGECOLOR 255 <span
class=3DSpellE>255</span> <span =
class=3DSpellE>255</span><o:p></o:p></span></font></p>
</span>COLOR 0 <span class=3DSpellE>0</span> <span =
class=3DSpellE>0</span><o:p></o:p></span></font></p>
</span>SIZE small<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>STYLE =
1<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>SIZE =
250 4<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>COLOR =
0 <span
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>UNITS
KILOMETERS<o:p></o:p></span></font></p>
</span>INTERVALS 5<o:p></o:p></span></font></p>
</span>TRANSPARENT
TRUE<o:p></o:p></span></font></p>
font-family:Arial'># Start of symbol =
definitions<o:p></o:p></span></font></p>
font-family:Arial'>SYMBOL<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>NAME =
'circle'<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>TYPE =
ellipse<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>FILLED =
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>POINTS =
1 <span
class=3DSpellE>1</span> END<o:p></o:p></span></font></p>
font-family:Arial'># Start of layer =
font-family:Arial'>########## RASTER =
##############<o:p></o:p></span></font></p>
font-family:Arial'>LAYER<o:p></o:p></span></font></p>
topo8<o:p></o:p></span></font></p>
RASTER<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>DATA =
topo8.tif<o:p></o:p></span></font></p>
OFF<o:p></o:p></span></font></p>
</span>PROJECTION<o:p></o:p></span></font></p>
</span>"<span
class=3DSpellE><span class=3DGramE>proj</span></span><span =
class=3DGramE>=3D</span><span
class=3DSpellE>latlong</span>"<o:p></o:p></span></font></p>
</span>"<span
class=3DSpellE><span class=3DGramE>ellps</span></span><span =
class=3DGramE>=3D</span>WGS84"
# Geographic<o:p></o:p></span></font></p>
font-family:Arial'>END # Map File<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D INITIALIZE FILE =
font-family:Arial'><<span =
class=3DGramE>html</span>><o:p></o:p></span></font></p>
</span><<span
class=3DGramE>head</span>><o:p></o:p></span></font></p>
</span><<span class=3DGramE>title></span>Maps Downunder <span =
class=3DSpellE>GioFinder</span>
Application</title><o:p></o:p></span></font></p>
</span><script language=3D"<span =
class=3DSpellE>javascript</span>"><o:p></o:p></span></font></p>
class=3DGramE>function</span> <span class=3DSpellE>submit_form</span>() =
{<o:p></o:p></span></font></p>
</span><span
class=3DSpellE><span class=3DGramE>var</span></span> template =3D <span =
class=3DSpellE>document.demo.map_web_template.options</span>[<span
class=3DSpellE>document.demo.map_web_template.selectedIndex</span>].value=
;<o:p></o:p></span></font></p>
</span><span
class=3DGramE>if(</span><span =
class=3DSpellE>template.indexOf</span>("frame")
!=3D -1) <span class=3DSpellE>document.demo.action</span> =3D
"frames.html";<o:p></o:p></span></font></p>
</span><span
class=3DSpellE>template.indexOf</span>("<span
class=3DSpellE>dhtml</span>") !=3D -1) <span =
=3D "frames_dhtml.html";<o:p></o:p></span></font></p>
</span><<span
</span><span
</span><span
</span><span
</span>}<o:p></o:p></span></font></p>
</span></script><o:p></o:p></span></font></p>
</span><span
</span><span
</span><span
</span></head><o:p></o:p></span></font></p>
</span><body <span
class=3DSpellE>bgcolor</span>=3D"#FFFFFF"><o:p></o:p></span>=
</font></p>
</span><<span class=3DGramE>center</span>><h2>Maps Downunder =
<span
class=3DSpellE>GioFinder</span> =
Application</h2></center><o:p></o:p></span></font></p>
</span><p><hr><p><o:p></o:p></span></font></p>
</span>This demonstration application will take you through various =
levels of
complexity. Starting with a basic application =
that<o:p></o:p></span></font></p>
</span><span
class=3DGramE>allows</span> a user to pan/zoom and change layers we =
add:<o:p></o:p></span></font></p>
</span><<span class=3DSpellE><span =
class=3DGramE>ul</span></span>><o:p></o:p></span></font></p>
</span><<span
class=3DSpellE><span class=3DGramE>li</span></span>> dynamically =
configured <span
class=3DSpellE>scalebars</span><o:p></o:p></span></font></p>
</span><<span
class=3DSpellE><span class=3DGramE>li</span></span>> <span =
class=3DSpellE>javascript</span>-based
panning<o:p></o:p></span></font></p>
</span><<span
class=3DSpellE><span class=3DGramE>li</span></span>> query results to =
a frame<o:p></o:p></span></font></p>
</span><span
style=3D'mso-spacerun:yes'> </span><<span =
class=3DGramE>li</span></span>> and finally, a DHTML rubber-band =
zoom/query <span
class=3DSpellE>capabilty</span><o:p></o:p></span></font></p>
</span></<span =
class=3DSpellE>ul</span>><o:p></o:p></span></font></p>
</span><span
class=3DGramE><!--</span> EDIT THE FORM ACTION =
--><o:p></o:p></span></font></p>
</span><form name=3D"demo" method=3D"GET"
action=3D"/cgi-bin/mapserv40" <span =
class=3DSpellE>onSubmit</span>=3D"<span
class=3DSpellE>submit_<span class=3DGramE>form</span></span><span =
class=3DGramE>(</span>)"><o:p></o:p></span></font></p>
font-family:Arial'><!--<o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"layer" =
value=3D"contours"><o:p></o:p></span></font></p>
</span><input
value=3D"dlgstln2"><o:p></o:p></span></font></p>
font-family:Arial'>--><o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"<span =
class=3DSpellE>zoomsize</span>"
value=3D2><o:p></o:p></span></font></p>
class=3DGramE><!--</span> EDIT THESE HIDDEN VARIABLES =
</span><input
type=3D"hidden" name=3D"map" value=3D"/<span =
class=3DSpellE>var/www/html/maps/giofinder/world.map</span>"><o:p=
</span><input
type=3D"hidden" name=3D"program"
value=3D"/cgi-bin/mapserv40"><o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"root" value=3D"/<span =
class=3DSpellE>giofinder</span>"><o:p></o:p></span></font></p>
</span><input
class=3DSpellE>map_web_imagepath</span>"
value=3D"/<span =
class=3DSpellE>var/www/html/maps/giofinder/tmp</span>/"><o:p></o:=
</span><input
class=3DSpellE>map_web_imageurl</span>"
value=3D"/<span =
class=3DSpellE>giofinder/tmp</span>/"><o:p></o:p></span></font></=
p>
</span><select
name=3D"<span class=3DSpellE>map_web_template</span>"
size=3D"1"><o:p></o:p></span></font></p>
</span><option value=3D"giofinder_basic.html"> Basic =
Application<o:p></o:p></span></font></p>
</span><option value=3D"giofinder_adds_scalebar.html"> =
&<span
class=3DSpellE>nbsp<span class=3DGramE>;&</span>nbsp</span>;-- Adds =
second <span
</span><option value=3D"giofinder_adds_pan.html"> =
&<span
pan
controls<o:p></o:p></span></font></p>
</span><option value=3D"giofinder_adds_frames.html"> =
&<span
frames<o:p></o:p></span></font></p>
</span><option value=3D"giofinder_adds_dhtml.html"> =
&<span
<span
class=3DSpellE>dhtml</span> rubber-band box<o:p></o:p></span></font></p>
</span></select><o:p></o:p></span></font></p>
</span><input
type=3D"submit" =
value=3D"Initialize"></center><o:p></o:p></span></font=
></p>
</span></form><o:p></o:p></span></font></p>
</span></body><o:p></o:p></span></font></p>
font-family:Arial'></html><o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D TEMPLATE HTML =
</span><<span
</span><span
</span><span
</span><span
</span><<span
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span><span
style=3D'mso-spacerun:yes'> </span><script =
language=3D"<span
</span><span
</span><span
!=3D -1) <span class=3DSpellE>document.demo.action</span> =3D =
</span><span
</span><span
</span><span
</span><span
</span><<span
</span><<span
class=3DGramE>title></span>Maps Downunder - <span =
font-family:Arial'></head><o:p></o:p></span></font></p>
font-family:Arial'><body <span =
class=3DSpellE>bgcolor</span>=3D"#<span
class=3DSpellE>ffffff</span>"><o:p></o:p></span></font></p>
class=3DGramE>center</span>><h1>Maps
Downunder - <span class=3DSpellE>GioFinder</span>
Application</h1></center><o:p></o:p></span></font></p>
class=3DGramE>hr</span>><o:p></o:p></span></font></p>
font-family:Arial'><form method=3D"GET" =
action=3D"[program]"
name=3D"<span =
class=3DSpellE>mapserv</span>"><o:p></o:p></span></font></p>
class=3DGramE>center</span>><o:p></o:p></span></font></p>
font-family:Arial'><table border=3D"0" <span =
class=3DSpellE>cellspacing</span>=3D"0"
<span =
class=3DSpellE>cellpadding</span>=3D"4"><o:p></o:p></span></=
font></p>
font-family:Arial'><<span class=3DSpellE><span =
class=3DGramE>tr</span></span>><o:p></o:p></span></font></p>
font-family:Arial'><td <span =
class=3DSpellE>valign</span>=3D"top"
align=3D"center"><o:p></o:p></span></font></p>
</span><table
width=3D"390" border=3D"0" <span =
<span class=3DSpellE>cellpadding</span>=3D"4" =
align=3D"center" <span
class=3DSpellE>bgcolor</span>=3D"#666666"><o:p></o:p></span>=
</font></p>
style=3D'mso-spacerun:yes'> </span><td
align=3D"center"><input type=3D"image" =
name=3D"<span
class=3DSpellE>img</span>" <span =
class=3DSpellE>src</span>=3D"[<span
class=3DSpellE>img</span>]" width=3D"[<span =
class=3DSpellE>mapwidth</span>]"
height=3D"[<span class=3DSpellE>mapheight</span>]" =
border=3D"0"
alt=3D"this is the =
map"></td><o:p></o:p></span></font></p>
</span></<span class=3DSpellE><span =
class=3DGramE>tr</span></span>><td <span
</font></p>
</span><<span
class=3DSpellE>img</span> title=3D"<span =
(mi)" alt=3D"<span class=3DSpellE>scalebar</span> (mi)" =
<span
class=3DSpellE>src</span>=3D"[<span =
class=3DSpellE>scalebar</span>]"><o:p></o:p></span></font></p>
</span></td></<span class=3DSpellE><span =
</span></table><o:p></o:p></span></font></p>
font-family:Arial'></td><o:p></o:p></span></font></p>
class=3DSpellE>valign</span>=3D"top" <span
class=3DSpellE>bgcolor</span>=3D"#<span =
</span><table <span
class=3DSpellE>cellpadding</span>=3D"5" <span =
class=3DGramE>tr</span></span>><td><o:p></o:p></span></font></p>=
</span><<span
class=3DGramE>center</span>><input type=3D"submit"
value=3D"Refresh/Query"></center><o:p></o:p></span></f=
ont></p>
</span><p><o:p></o:p></span></font></p>
</span><input
type=3D"radio" name=3D"mode" =
value=3D"browse"
checked> <b>Browse map</b><<span =
class=3DSpellE>br</span>><o:p></o:p></span></font></p>
</span><input
value=3D"query">
<b>Query feature</b><<span =
</span><input
type=3D"radio" name=3D"mode" value=3D"<span =
class=3DSpellE>nquery</span>">
<b>Query multiple features</b><o:p></o:p></span></font></p>
</span><<span
</span><b>Select
Layers to Display: </b><<span =
</span><select
multiple name=3D"layer" =
size=3D3><o:p></o:p></span></font></p>
</span><option value=3D"contours" [<span =
class=3DSpellE>contours_select</span>]>
Contours<o:p></o:p></span></font></p>
</span><option value=3D"<span =
class=3DSpellE>waterbodies</span>" [<span
class=3DSpellE>waterbodies_select</span>]> Lakes & =
Rivers<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><!--</span></font></span>=
<font
style=3D'font-size:10.0pt;font-family:Arial'><span
</span><option value=3D"lakespy2" [lakespy2_select]> =
Lakes &
</span><option value=3D"dlgstln2" [dlgstln2_select]> =
Streams<o:p></o:p></span></font></p>
</span><option value=3D"roads" [<span =
class=3DSpellE>roads_select</span>]>
Roads<o:p></o:p></span></font></p>
</span><option value=3D"twprgpy3" [twprgpy3_select]> =
Townships<o:p></o:p></span></font></p>
</span><option value=3D"<span class=3DSpellE>drgs</span>" =
[<span
class=3DSpellE>drgs_select</span>]> USGS 1:250,000 =
Quads<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>Zoom In =
<input
type=3Dradio name=3D<span class=3DSpellE>zoomdir</span> value=3D1 =
[zoomdir_1_check]><o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>Pan =
<input
type=3Dradio name=3D<span class=3DSpellE>zoomdir</span> value=3D0 =
[zoomdir_0_check]><o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>Zoom =
Out
<input type=3Dradio name=3D<span class=3DSpellE>zoomdir</span> =
value=3D-1
[zoomdir_-1_check]><o:p></o:p></span></font></p>
Size
<input type=3Dtext name=3D<span class=3DSpellE>zoomsize</span> =
size=3D4 value<span
class=3DGramE>=3D[</span><span =
class=3DSpellE>zoomsize</span>]><o:p></o:p></span></font></p>
</span><font
size=3D+1><b>Legend</b></font><<span =
class=3DSpellE>br</span>><hr><o:p></o:p></span></font></p>
</span><<span
class=3DSpellE>img</span> <span =
class=3DSpellE>src</span>=3D"[legend]"><hr><o:p></o:p>=
</span></font></p>
</span><center><input name=3D"ref" =
type=3D"image" <span
class=3DSpellE>src</span>=3D"[ref]"
border=3D"0"></center><o:p></o:p></span></font></p>
class=3DGramE>tr</span></span>></table><o:p></o:p></span></font>=
</p>
font-family:Arial'></table><o:p></o:p></span></font></p>
font-family:Arial'></center><o:p></o:p></span></font></p>
font-family:Arial'><input type=3D"hidden" =
name=3D"<span
class=3DSpellE>imgxy</span>" =
value=3D"[center]"><o:p></o:p></span></font></p>
name=3D"<span
class=3DSpellE>imgext</span>" value=3D"[<span =
class=3DSpellE>mapext</span>]"><o:p></o:p></span></font></p>
name=3D"map"
value=3D"[map]"><o:p></o:p></span></font></p>
name=3D"root"
value=3D"[root]"><o:p></o:p></span></font></p>
name=3D"<span
class=3DSpellE>savequery</span>" =
value=3D"true"><o:p></o:p></span></font></p>
name=3D"program"
value=3D"[program]"><o:p></o:p></span></font></p>
name=3D"<span
class=3DSpellE>map_web_imagepath</span>" value=3D"[<span =
class=3DSpellE>map_web_imagepath</span>]"><o:p></o:p></span></fon=
t></p>
name=3D"<span
class=3DSpellE>map_web_imageurl</span>" value=3D"[<span =
class=3DSpellE>map_web_imageurl</span>]"><o:p></o:p></span></font=
></p>
name=3D"<span
class=3DSpellE>map_web_template</span>" value=3D"[<span =
class=3DSpellE>map_web_template</span>]"><o:p></o:p></span></font=
></p>
font-family:Arial'></form><o:p></o:p></span></font></p>
font-family:Arial'><p><hr><p><o:p></o:p></span></font><=
/p>
font-family:Arial'><a <span =
class=3DSpellE>href</span>=3D"[root]/index.html">back
to start</a><p><o:p></o:p></span></font></p>
font-family:Arial'><<span class=3DSpellE>i</span><span =
class=3DGramE>>[</span><span
class=3DSpellE>map_web_template</span>]</<span =
class=3DSpellE>i</span>><o:p></o:p></span></font></p>
font-family:Arial'></body></html><o:p></o:p></span></font></p=
</div>
</body>
</html>
------=_NextPart_000_000C_01C44ADD.03542310--
