[Mapserver-users] Tiled Tiff problem solved
Frank Warmerdam
warmerdam at pobox.com
Sat Jun 5 10:09:02 EDT 2004
John Wiley wrote:
> I heard ermapper was a go...
>>>>"Wim Blanken (PI)" <wim.blanken at planet.nl> 06/04/04 11:46am >>>
> Hello Mapserver lovers,
> We had a problem using tiled tiffs in our mapserver application. Our favourite image converter (XNVIEW) could not convert these to 8 bits tiff in batch for use in mapserver. We downloaded a trial version of PMVIEW and this package does the job perfectly so it is a nice work around. Does however anyone know an opensource package that can handle and convert tiled tiffs? (packbits compressed). Does GIMP cover this?
Wim / John,
Note that GDAL can be used to read and convert tiled TIFFs. For that matter,
if you build MapServer with GDAL support (and not the limited built-in TIFF
support) you can use tiled tiffs directly in MapServer, often with better
performance than stripped tiffs.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
