[Mapserver-users] Blank or no image returned
Andrew Rich
devel at itdownunder.com.au
Mon Jun 7 05:50:59 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0004_01C44CC8.C30C4D30
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi All
I have it working now!
I will leave the text below for reference.
Basically I was not loading the Image in my hack of the Itasca demo.
Once I configured a Layer to include this image and have that layer load
automatically it worked.
Thank you to any one who read this even if I didn't receive a reply.
Andrew Rich
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Andrew
Rich
Sent: Saturday, 5 June 2004 9:11 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Blank or no image returned
Hi All
I have Mapserv 4.2 installed and works with Itasca demo.
I am now modifying the Itasca demo and using a image of the world in
TOPO8.TIF
Tyler has given me a .map file which I am adjusting to the paths of my
mapserv server.
When loading the Initialize file the renamed Itasca demo for shows then
select the basic application. The normal Itasca screen shows but the
box is just the color set in IMAGECOLOR 100 100 255. It was 255 255 255
which was white but I changed to this blue for testing.
The scale bar in the lower left corner is in Kilometres and adjusts on
Zoom In and Out.
I have included a lot of information below but I need assistance to move
on I think.
I saw in a previous post that it may be related to the projection but my
knowledge of these topics is very limited.
Thank you for any assistance.
Andrew Rich
Maps Downunder
==== mapserv40 -v ====
MapServer version 4.2.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
==== ldd /var/www/cgi-bin/mapserv40 ====
libgd.so.2 => /usr/local/lib/libgd.so.2 (0x4002b000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40064000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40082000)
libpng.so.3 => /usr/local/lib/libpng.so.3 (0x400c1000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x400ee000)
libgdal.so.1 => /usr/local/lib/libgdal.so.1 (0x40121000)
libcurl.so.3 => /usr/local/lib/libcurl.so.3 (0x40417000)
libdl.so.2 => /lib/libdl.so.2 (0x40444000)
libm.so.6 => /lib/i686/libm.so.6 (0x40447000)
libc.so.6 => /lib/i686/libc.so.6 (0x42000000)
libpthread.so.0 => /lib/i686/libpthread.so.0 (0x40469000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x4047d000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x4048b000)
libpng12.so.0 => /usr/local/lib/libpng12.so.0 (0x40561000)
libz.so.1 => /usr/lib/libz.so.1 (0x4058e000)
libodbc.so.1 => /usr/lib/libodbc.so.1 (0x4059c000)
libungif.so.4 => /usr/lib/libungif.so.4 (0x405f9000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x40601000)
libssl.so.2 => /lib/libssl.so.2 (0x40644000)
libcrypto.so.2 => /lib/libcrypto.so.2 (0x40672000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
==== /etc/ld.so.conf ====
/usr/kerberos/lib
/usr/X11R6/lib
/usr/lib/qt2/lib
/usr/lib/mysql
/usr/lib/qt-3.0.5/lib
/usr/lib/sane
/usr/local/lib
/usr/lib/python1.5/site-packages
==== MAP FILE ====
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 400
EXTENT -180 -90 180 90 # Whole world
UNITS DD
SHAPEPATH "data"
#FONTSET "/usr/src/mapserver-4.2.0/tests/fonts.txt"
CONFIG GDAL_DATA "data"
IMAGETYPE PNG
# OUTPUTFORMAT
# NAME "gif"
# MIMETYPE "image/gif"
# DRIVER "GD/GIF"
# EXTENSION "gif"
# IMAGEMODE PC256
# TRANSPARENT FALSE
# END
# Projection definition, consult the PROJ.4 documentation for parameter
discussi
PROJECTION
"init=epsg:4326"
END
# Start of web interface definition
WEB
#HEADER demo_header.html
TEMPLATE giofinder_basic.html
#FOOTER demo_footer.html
IMAGEPATH "/var/www/html/maps/giofinder/tmp"
IMAGEURL "/giofinder/tmp/"
END
# Start of reference map
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 400
UNITS DD
SHAPEPATH "data"
IMAGETYPE PNG
# OUTPUTFORMAT
# NAME "gif"
# DRIVER "GD/GIF"
# EXTENSION "gif"
# IMAGEMODE PC256
# TRANSPARENT FALSE
# END
discussi
PROJECTION
"init=epsg:4326"
END
WEB
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE small
END
STYLE 1
SIZE 250 4
COLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
TRANSPARENT FALSE
STATUS TRUE
END
# Start of symbol definitions
SYMBOL
NAME 'circle'
TYPE ellipse
FILLED TRUE
POINTS 1 1 END
END
# Start of layer definitions
########## RASTER ##############
LAYER
NAME topo8
TYPE RASTER
DATA topo8.tif
STATUS OFF
PROJECTION
"proj=latlong"
"ellps=WGS84" # Geographic
END
END
END # Map File
==== INITIALIZE FILE ====
<html>
<head>
<title>Maps Downunder GioFinder Application</title>
<script language="javascript">
function submit_form() {
var template =
document.demo.map_web_template.options[document.demo.map_web_template.se
lectedIndex].value;
if(template.indexOf("frame") != -1) document.demo.action =
"frames.html";
if(template.indexOf("dhtml") != -1) document.demo.action =
"frames_dhtml.html";
<html>
<head>
var template =
lectedIndex].value;
"frames.html";
</script>
var template =
lectedIndex].value;
"frames.html";
</script>
</head>
<body bgcolor="#FFFFFF">
<center><h2>Maps Downunder GioFinder Application</h2></center>
<p><hr><p>
This demonstration application will take you through various levels
of complexity. Starting with a basic application that
allows a user to pan/zoom and change layers we add:
<ul>
<li> dynamically configured scalebars
<li> javascript-based panning
<li> query results to a frame
<li> and finally, a DHTML rubber-band zoom/query capabilty
</ul>
<!-- EDIT THE FORM ACTION -->
<form name="demo" method="GET" action="/cgi-bin/mapserv40"
onSubmit="submit_form()">
<input type="hidden" name="layer" value="contours">
<input type="hidden" name="layer" value="dlgstln2">
<input type="hidden" name="zoomsize" value=2>
<!-- EDIT THESE HIDDEN VARIABLES -->
<input type="hidden" name="map"
value="/var/www/html/maps/giofinder/world.map">
<input type="hidden" name="program" value="/cgi-bin/mapserv40">
<input type="hidden" name="root" value="/giofinder">
<input type="hidden" name="map_web_imagepath"
value="/var/www/html/maps/giofinder/tmp/">
<input type="hidden" name="map_web_imageurl"
value="/giofinder/tmp/">
<select name="map_web_template" size="1">
<option value="giofinder_basic.html"> Basic Application
<option value="giofinder_adds_scalebar.html"> --
Adds second scalebar
<option value="giofinder_adds_pan.html"> -- Adds pan
controls
<option value="giofinder_adds_frames.html"> -- Adds
frames
<option value="giofinder_adds_dhtml.html"> -- Adds
dhtml rubber-band box
</select>
<input type="submit" value="Initialize"></center>
</form>
<p><hr><p>
</body>
</html>
==== TEMPLATE HTML ====
<html>
<head>
var template =
lectedIndex].value;
"frames.html";
<html>
<head>
var template =
lectedIndex].value;
"frames.html";
</script>
var template =
lectedIndex].value;
"frames.html";
</script>
<html>
<head>
<html>
<head>
<title>Maps Downunder - GioFinder Application</title>
</head>
<body bgcolor="#ffffff">
<center><h1>Maps Downunder - GioFinder Application</h1></center>
<hr>
<form method="GET" action="[program]" name="mapserv">
<center>
<table border="0" cellspacing="0" cellpadding="4">
<tr>
<td valign="top" align="center">
<table width="390" border="0" cellspacing="0" cellpadding="4"
align="center" bgcolor="#666666">
<tr>
<td align="center"><input type="image" name="img" src="[img]"
width="[mapwidth]" height="[mapheight]" border="0" alt="this is the
map"></td>
</tr>
<tr><td bgcolor="#666666">
<img title="scalebar (mi)" alt="scalebar (mi)" src="[scalebar]">
</td></tr>
</table>
</td>
<td valign="top" bgcolor="#ffffff">
<table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
<tr><td>
<center><input type="submit" value="Refresh/Query"></center>
<p>
<input type="radio" name="mode" value="browse" checked> <b>Browse
map</b><br>
<input type="radio" name="mode" value="query"> <b>Query
feature</b><br>
<input type="radio" name="mode" value="nquery"> <b>Query multiple
features</b>
<hr>
<p>
<b>Select Layers to Display: </b><br>
<select multiple name="layer" size=3>
<option value="contours" [contours_select]> Contours
<option value="waterbodies" [waterbodies_select]> Lakes & Rivers
<!-- <option value="lakespy2" [lakespy2_select]> Lakes & Rivers
<option value="dlgstln2" [dlgstln2_select]> Streams
<option value="roads" [roads_select]> Roads
<option value="twprgpy3" [twprgpy3_select]> Townships
<option value="drgs" [drgs_select]> USGS 1:250,000 Quads
</select>
<p>
Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
Zoom Out <input type=radio name=zoomdir value=-1
[zoomdir_-1_check]>
<p>
Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
<p>
<font size=+1><b>Legend</b></font><br><hr>
<img src="[legend]"><hr>
<p>
<center><input name="ref" type="image" src="[ref]"
border="0"></center>
</td></tr></table>
</td></tr>
</table>
</center>
<input type="hidden" name="imgxy" value="[center]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="root" value="[root]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="program" value="[program]">
value="[map_web_imagepath]">
<input type="hidden" name="map_web_imageurl" value="[map_web_imageurl]">
<input type="hidden" name="map_web_template" value="[map_web_template]">
</form>
<p><hr><p>
<a href="[root]/index.html">back to start</a><p>
<i>[map_web_template]</i>
</body></html>
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44CC8.C0C7B460">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"time"/>
<o:SmartTagType =
name=3D"date"/>
<o:SmartTagType =
name=3D"City"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle18
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Hi All<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>I have it working =
now!<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>I will leave the text below for =
reference.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Basically I was not loading the =
Image in
my hack of the </span></font><st1:place><font size=3D2 color=3Dnavy =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>Itasca</span></fo=
nt></st1:place><font
color:navy'> demo.<span style=3D'mso-spacerun:yes'> =
</span><o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Once I configured a Layer to =
include this image
and have that layer load automatically it =
worked.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Thank you to any one who read this =
even if
I didn’t receive a reply.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Andrew =
Rich<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
<div style=3D'border:none;border-left:solid blue 1.5pt;padding:0cm 0cm =
0cm 4.0pt'>
<p class=3DMsoNormal><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>-----Original Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b>
[mailto:mapserver-users-admin at lists.gis.umn.edu] <b><span =
bold'>On Behalf Of </span></b>Andrew Rich<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> =
</span></font><st1:date
Year=3D"2004" Day=3D"5" Month=3D"6"><font size=3D2 face=3DTahoma><span =
style=3D'font-size:
10.0pt;font-family:Tahoma'>Saturday, 5 June =
2004</span></font></st1:date><font
style=3D'font-size:10.0pt;font-family:Tahoma'> </span></font><st1:time
Minute=3D"11" Hour=3D"9"><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>9:11 AM</span></font></st1:time><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'><br>
<b><span style=3D'font-weight:bold'>To:</span></b> =
mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
or no image returned</span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
font-family:Arial'>Hi All<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I have Mapserv 4.2 installed and works with =
style=3D'font-size:10.0pt;font-family:Arial'>Itasca</span></font></st1:pl=
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> =
demo.<o:p></o:p></span></font></p>
font-family:Arial'>I am now modifying the </span></font><st1:place><font
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> demo and
using a image of the world in TOPO8.TIF<o:p></o:p></span></font></p>
<p class=3DMsoNormal><st1:City><st1:place><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Tyler</span></font></st1:pla=
ce></st1:City><font
style=3D'font-size:10.0pt;font-family:Arial'> has given
me a .map file which I am adjusting to the paths of my mapserv =
server.<o:p></o:p></span></font></p>
font-family:Arial'>When loading the Initialize file the renamed =
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> demo for
shows then select the basic application.<span =
</span>The normal </span></font><st1:place><font size=3D2 =
face=3DArial><span
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> screen
shows but the box is just the color set in IMAGECOLOR 100 100 255.<span
style=3D'mso-spacerun:yes'> </span>It was 255 255 255 which was =
white but I
changed to this blue for testing.<o:p></o:p></span></font></p>
font-family:Arial'>The scale bar in the lower left corner is in =
Kilometres and
adjusts on Zoom In and Out.<o:p></o:p></span></font></p>
font-family:Arial'>I have included a lot of information below but I need
assistance to move on I think.<span style=3D'mso-spacerun:yes'> =
font-family:Arial'>I saw in a previous post that it may be related to =
the
projection but my knowledge of these topics is very limited. =
font-family:Arial'>Thank you for any =
assistance.<o:p></o:p></span></font></p>
font-family:Arial'>Andrew Rich<o:p></o:p></span></font></p>
font-family:Arial'>Maps Downunder<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D mapserv40 –v =
=3D=3D=3D=3D<o:p></o:p></span></font></p>
font-family:Arial'>MapServer version 4.2.0 OUTPUT=3DPNG OUTPUT=3DJPEG =
OUTPUT=3DWBMP
SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=3DWMS_SERVER =
SUPPORTS=3DWMS_CLIENT
SUPPORTS=3DWFS_SERVER SUPPORTS=3DWFS_CLIENT INPUT=3DEPPL7 INPUT=3DOGR =
INPUT=3DGDAL
INPUT=3DSHAPEFILE<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D<span style=3D'mso-spacerun:yes'> =
</span>ldd
/var/www/cgi-bin/mapserv40 =3D=3D=3D=3D<o:p></o:p></span></font></p>
font-family:Arial'><span
</span>libgd.so.2 =3D> /usr/local/lib/libgd.so.2 =
(0x4002b000)<o:p></o:p></span></font></p>
</span>libjpeg.so.62 =3D> /usr/lib/libjpeg.so.62 =
(0x40064000)<o:p></o:p></span></font></p>
</span>libfreetype.so.6 =3D> /usr/lib/libfreetype.so.6 =
(0x40082000)<o:p></o:p></span></font></p>
</span>libpng.so.3 =3D> /usr/local/lib/libpng.so.3 =
(0x400c1000)<o:p></o:p></span></font></p>
</span>libproj.so.0 =3D> /usr/local/lib/libproj.so.0 =
(0x400ee000)<o:p></o:p></span></font></p>
</span>libgdal.so.1 =3D> /usr/local/lib/libgdal.so.1 =
(0x40121000)<o:p></o:p></span></font></p>
</span>libcurl.so.3 =3D> /usr/local/lib/libcurl.so.3 =
(0x40417000)<o:p></o:p></span></font></p>
</span>libdl.so.2 =3D> /lib/libdl.so.2 =
(0x40444000)<o:p></o:p></span></font></p>
</span>libm.so.6 =3D> /lib/i686/libm.so.6 =
(0x40447000)<o:p></o:p></span></font></p>
</span>libc.so.6 =3D> /lib/i686/libc.so.6 =
(0x42000000)<o:p></o:p></span></font></p>
</span>libpthread.so.0 =3D> /lib/i686/libpthread.so.0 =
(0x40469000)<o:p></o:p></span></font></p>
</span>libXpm.so.4 =3D> /usr/X11R6/lib/libXpm.so.4 =
(0x4047d000)<o:p></o:p></span></font></p>
</span>libX11.so.6 =3D> /usr/X11R6/lib/libX11.so.6 =
(0x4048b000)<o:p></o:p></span></font></p>
</span>libpng12.so.0 =3D> /usr/local/lib/libpng12.so.0 =
(0x40561000)<o:p></o:p></span></font></p>
</span>libz.so.1 =3D> /usr/lib/libz.so.1 =
(0x4058e000)<o:p></o:p></span></font></p>
</span>libodbc.so.1 =3D> /usr/lib/libodbc.so.1 =
(0x4059c000)<o:p></o:p></span></font></p>
</span>libungif.so.4 =3D> /usr/lib/libungif.so.4 =
(0x405f9000)<o:p></o:p></span></font></p>
</span>libstdc++-libc6.2-2.so.3 =3D> =
/usr/lib/libstdc++-libc6.2-2.so.3 =
(0x40601000)<o:p></o:p></span></font></p>
</span>libssl.so.2 =3D> /lib/libssl.so.2 =
(0x40644000)<o:p></o:p></span></font></p>
</span>libcrypto.so.2 =3D> /lib/libcrypto.so.2 =
(0x40672000)<o:p></o:p></span></font></p>
</span>/lib/ld-linux.so.2 =3D> /lib/ld-linux.so.2 =
(0x40000000)<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D /etc/ld.so.conf =
font-family:Arial'>/usr/kerberos/lib<o:p></o:p></span></font></p>
font-family:Arial'>/usr/X11R6/lib<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/qt2/lib<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/mysql<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/qt-3.0.5/lib<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/sane<o:p></o:p></span></font></p>
font-family:Arial'>/usr/local/lib<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/python1.5/site-packages<o:p></o:p></span></fo=
nt></p>
font-family:Arial'>=3D=3D=3D=3D MAP FILE =
font-family:Arial'>#<o:p></o:p></span></font></p>
font-family:Arial'># Start of map file<o:p></o:p></span></font></p>
font-family:Arial'>NAME DEMO<o:p></o:p></span></font></p>
font-family:Arial'>STATUS ON<o:p></o:p></span></font></p>
font-family:Arial'>SIZE 600 400<o:p></o:p></span></font></p>
font-family:Arial'>EXTENT -180 -90 180 90<span =
</span># Whole world<o:p></o:p></span></font></p>
font-family:Arial'>UNITS DD<o:p></o:p></span></font></p>
font-family:Arial'>SHAPEPATH =
"data"<o:p></o:p></span></font></p>
font-family:Arial'>IMAGECOLOR 100 100 255<o:p></o:p></span></font></p>
font-family:Arial'>#FONTSET
"/usr/src/mapserver-4.2.0/tests/fonts.txt"<o:p></o:p></span></f=
ont></p>
font-family:Arial'>CONFIG GDAL_DATA =
font-family:Arial'>IMAGETYPE PNG<o:p></o:p></span></font></p>
font-family:Arial'>#<span style=3D'mso-spacerun:yes'> =
</span>OUTPUTFORMAT<o:p></o:p></span></font></p>
</span>NAME "gif"<o:p></o:p></span></font></p>
</span>MIMETYPE "image/gif"<o:p></o:p></span></font></p>
</span>DRIVER "GD/GIF"<o:p></o:p></span></font></p>
</span>EXTENSION "gif"<o:p></o:p></span></font></p>
</span>IMAGEMODE PC256<o:p></o:p></span></font></p>
</span>TRANSPARENT FALSE<o:p></o:p></span></font></p>
</span>END<o:p></o:p></span></font></p>
font-family:Arial'># Projection definition, consult the PROJ.4 =
documentation
for parameter discussi<o:p></o:p></span></font></p>
font-family:Arial'>PROJECTION<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>
</span>"init=3Depsg:4326"<o:p></o:p></span></font></p>
font-family:Arial'>END<o:p></o:p></span></font></p>
font-family:Arial'># Start of web interface =
definition<o:p></o:p></span></font></p>
font-family:Arial'>WEB<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> =
</span>#HEADER
demo_header.html<o:p></o:p></span></font></p>
</span>TEMPLATE
giofinder_basic.html<o:p></o:p></span></font></p>
</span>#FOOTER demo_footer.html<o:p></o:p></span></font></p>
</span>IMAGEPATH
"/var/www/html/maps/giofinder/tmp"<o:p></o:p></span></font></p>=
</span>IMAGEURL
"/giofinder/tmp/"<o:p></o:p></span></font></p>
font-family:Arial'># Start of reference map<o:p></o:p></span></font></p>
font-family:Arial'># Start of legend<o:p></o:p></span></font></p>
font-family:Arial'>LEGEND<o:p></o:p></span></font></p>
</span>KEYSIZE 18 12<o:p></o:p></span></font></p>
</span>LABEL<o:p></o:p></span></font></p>
</span>TYPE BITMAP<o:p></o:p></span></font></p>
</span>SIZE MEDIUM<o:p></o:p></span></font></p>
</span>COLOR 0 0 89<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>STATUS =
ont></p>
</span>NAME
documentation
</span>#HEADER
</span>TEMPLATE
</span>#FOOTER
</span>IMAGEPATH
</span>IMAGEURL
font-family:Arial'># Start of scalebar<o:p></o:p></span></font></p>
font-family:Arial'>SCALEBAR<o:p></o:p></span></font></p>
</span>IMAGECOLOR 255
255 255<o:p></o:p></span></font></p>
</span>COLOR 0 0 0<o:p></o:p></span></font></p>
</span>SIZE small<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>STYLE =
1<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>SIZE =
250 4<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>COLOR =
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>UNITS
KILOMETERS<o:p></o:p></span></font></p>
</span>INTERVALS 5<o:p></o:p></span></font></p>
</span>TRANSPARENT
TRUE<o:p></o:p></span></font></p>
font-family:Arial'># Start of symbol =
definitions<o:p></o:p></span></font></p>
font-family:Arial'>SYMBOL<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>NAME =
'circle'<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>TYPE =
ellipse<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>FILLED =
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>POINTS =
1 1 END<o:p></o:p></span></font></p>
font-family:Arial'># Start of layer =
font-family:Arial'>########## RASTER =
##############<o:p></o:p></span></font></p>
font-family:Arial'>LAYER<o:p></o:p></span></font></p>
topo8<o:p></o:p></span></font></p>
RASTER<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>DATA =
topo8.tif<o:p></o:p></span></font></p>
OFF<o:p></o:p></span></font></p>
</span>PROJECTION<o:p></o:p></span></font></p>
</span>"proj=3Dlatlong"<o:p></o:p></span></font></p>
</span>"ellps=3DWGS84" # =
Geographic<o:p></o:p></span></font></p>
font-family:Arial'>END # Map File<o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D INITIALIZE FILE =
font-family:Arial'><html><o:p></o:p></span></font></p>
</span><head><o:p></o:p></span></font></p>
</span><title>Maps Downunder GioFinder =
Application</title><o:p></o:p></span></font></p>
</span><script =
language=3D"javascript"><o:p></o:p></span></font></p>
</span>function
submit_form() {<o:p></o:p></span></font></p>
</span>var
template =3D
document.demo.map_web_template.options[document.demo.map_web_template.sel=
ectedIndex].value;<o:p></o:p></span></font></p>
</span>if(template.indexOf("frame") !=3D -1) =
document.demo.action =3D
"frames.html";<o:p></o:p></span></font></p>
</span>if(template.indexOf("dhtml") !=3D -1) =
"frames_dhtml.html";<o:p></o:p></span></font></p>
</span><script =
</span>function
</span>var
template =3D =
</span>}<o:p></o:p></span></font></p>
</span></script><o:p></o:p></span></font></p>
</span><script =
</span>function
</span>var
template =3D
</span></head><o:p></o:p></span></font></p>
</span><body
bgcolor=3D"#FFFFFF"><o:p></o:p></span></font></p>
</span><center><h2>Maps Downunder GioFinder
Application</h2></center><o:p></o:p></span></font></p>
</span><span
style=3D'mso-spacerun:yes'> </span><p><hr><p><o:p>=
</span>This demonstration application will take you through various =
levels of
complexity. Starting with a basic application =
that<o:p></o:p></span></font></p>
</span>allows a user to pan/zoom and change layers we =
add:<o:p></o:p></span></font></p>
</span><ul><o:p></o:p></span></font></p>
</span><li>
dynamically configured scalebars<o:p></o:p></span></font></p>
</span><li>
javascript-based panning<o:p></o:p></span></font></p>
</span><li> query
results to a frame<o:p></o:p></span></font></p>
</span><li> and
finally, a DHTML rubber-band zoom/query =
capabilty<o:p></o:p></span></font></p>
</span></ul><o:p></o:p></span></font></p>
</span><!-- EDIT THE FORM ACTION --><o:p></o:p></span></font></p>
</span><form name=3D"demo" method=3D"GET"
action=3D"/cgi-bin/mapserv40" =
onSubmit=3D"submit_form()"><o:p></o:p></span></font></p>
font-family:Arial'><!--<o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"layer" =
value=3D"contours"><o:p></o:p></span></font></p>
</span><input
value=3D"dlgstln2"><o:p></o:p></span></font></p>
font-family:Arial'>--><o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"zoomsize" =
value=3D2><o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span><!-- =
EDIT
THESE HIDDEN VARIABLES --><o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"map"
value=3D"/var/www/html/maps/giofinder/world.map"><o:p></o:p>=
</span></font></p>
</span><input
type=3D"hidden" name=3D"program"
value=3D"/cgi-bin/mapserv40"><o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"root" =
value=3D"/giofinder"><o:p></o:p></span></font></p>
</span><input
type=3D"hidden" name=3D"map_web_imagepath"
value=3D"/var/www/html/maps/giofinder/tmp/"><o:p></o:p></spa=
n></font></p>
</span><input
type=3D"hidden" name=3D"map_web_imageurl"
value=3D"/giofinder/tmp/"><o:p></o:p></span></font></p>
</span><select
name=3D"map_web_template" =
size=3D"1"><o:p></o:p></span></font></p>
</span><option value=3D"giofinder_basic.html"> Basic =
Application<o:p></o:p></span></font></p>
</span><option value=3D"giofinder_adds_scalebar.html">
&nbsp;&nbsp;-- Adds second scalebar<o:p></o:p></span></font></p>
</span><option value=3D"giofinder_adds_pan.html">
&nbsp;&nbsp;-- Adds pan controls<o:p></o:p></span></font></p>
</span><option value=3D"giofinder_adds_frames.html">
&nbsp;&nbsp;-- Adds frames<o:p></o:p></span></font></p>
</span><option value=3D"giofinder_adds_dhtml.html">
&nbsp;&nbsp;-- Adds dhtml rubber-band =
box<o:p></o:p></span></font></p>
</span></select><o:p></o:p></span></font></p>
</span><input
type=3D"submit" =
value=3D"Initialize"></center><o:p></o:p></span></font=
></p>
</span></form><o:p></o:p></span></font></p>
</span><p><hr><p><o:p></o:p></span></font></p>
</span></body><o:p></o:p></span></font></p>
font-family:Arial'></html><o:p></o:p></span></font></p>
font-family:Arial'>=3D=3D=3D=3D TEMPLATE HTML =
</span><script =
</span>function
</span>var
template =3D
</span><script =
</span>function
</span><span
style=3D'mso-spacerun:yes'> </span>var =
template =3D
</span><script =
</span>function
</span>var
template =3D
font-family:Arial'><head><o:p></o:p></span></font></p>
</span><title>Maps Downunder - GioFinder =
font-family:Arial'></head><o:p></o:p></span></font></p>
font-family:Arial'><body =
bgcolor=3D"#ffffff"><o:p></o:p></span></font></p>
font-family:Arial'><center><h1>Maps Downunder - GioFinder
Application</h1></center><o:p></o:p></span></font></p>
font-family:Arial'><hr><o:p></o:p></span></font></p>
font-family:Arial'><form method=3D"GET" =
action=3D"[program]"
name=3D"mapserv"><o:p></o:p></span></font></p>
font-family:Arial'><center><o:p></o:p></span></font></p>
font-family:Arial'><table border=3D"0" =
cellspacing=3D"0"
cellpadding=3D"4"><o:p></o:p></span></font></p>
font-family:Arial'><tr><o:p></o:p></span></font></p>
font-family:Arial'><td valign=3D"top" =
align=3D"center"><o:p></o:p></span></font></p>
</span><table
width=3D"390" border=3D"0" =
cellspacing=3D"0"
cellpadding=3D"4" align=3D"center"
bgcolor=3D"#666666"><o:p></o:p></span></font></p>
</span><tr><o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span><td
align=3D"center"><input type=3D"image"
name=3D"img" src=3D"[img]" =
width=3D"[mapwidth]"
height=3D"[mapheight]" border=3D"0" alt=3D"this =
is the
map"></td><o:p></o:p></span></font></p>
</span></tr><o:p></o:p></span></font></p>
</span><tr><td =
style=3D'mso-spacerun:yes'> </span><img
title=3D"scalebar (mi)" alt=3D"scalebar (mi)"
src=3D"[scalebar]"><o:p></o:p></span></font></p>
</span></td></tr><o:p></o:p></span></font></p>
</span></table><o:p></o:p></span></font></p>
font-family:Arial'></td><o:p></o:p></span></font></p>
</span><table
cellpadding=3D"5" cellspacing=3D"0" =
border=3D"0"
</span><tr><td><o:p></o:p></span></font></p>
</span><center><input type=3D"submit"
value=3D"Refresh/Query"></center><o:p></o:p></span></f=
ont></p>
</span><p><o:p></o:p></span></font></p>
</span><input
type=3D"radio" name=3D"mode" =
value=3D"browse"
checked> <b>Browse =
map</b><br><o:p></o:p></span></font></p>
</span><input
value=3D"query">
<b>Query feature</b><br><o:p></o:p></span></font></p>
</span><input type=3D"radio"
name=3D"mode" value=3D"nquery"> <b>Query =
multiple
features</b><o:p></o:p></span></font></p>
</span><hr><o:p></o:p></span></font></p>
</span><b>Select
Layers to Display: </b><br><o:p></o:p></span></font></p>
</span><select
multiple name=3D"layer" =
size=3D3><o:p></o:p></span></font></p>
</span><option value=3D"contours" [contours_select]> =
Contours<o:p></o:p></span></font></p>
</span><option
value=3D"waterbodies" [waterbodies_select]> Lakes & =
Rivers<o:p></o:p></span></font></p>
font-family:Arial'><!--<span
</span><option value=3D"lakespy2" [lakespy2_select]> =
Lakes &
</span><option value=3D"dlgstln2" [dlgstln2_select]> =
Streams<o:p></o:p></span></font></p>
</span><option value=3D"roads" [roads_select]> =
Roads<o:p></o:p></span></font></p>
</span><option
value=3D"twprgpy3" [twprgpy3_select]> =
Townships<o:p></o:p></span></font></p>
</span><option value=3D"drgs" [drgs_select]> USGS =
1:250,000 Quads<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>Zoom In
<input type=3Dradio name=3Dzoomdir value=3D1 =
[zoomdir_1_check]><o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>Pan =
<input
type=3Dradio name=3Dzoomdir value=3D0 =
[zoomdir_0_check]><o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'> </span>Zoom =
Out
<input type=3Dradio name=3Dzoomdir value=3D-1 =
[zoomdir_-1_check]><o:p></o:p></span></font></p>
Size
<input type=3Dtext name=3Dzoomsize size=3D4 =
value=3D[zoomsize]><o:p></o:p></span></font></p>
</span><font
size=3D+1><b>Legend</b></font><br><hr><o=
src=3D"[legend]"><hr><o:p></o:p></span></font></p>
</span><center><input name=3D"ref" =
type=3D"image"
src=3D"[ref]" =
border=3D"0"></center><o:p></o:p></span></font></p>
</span></td></tr></table><o:p></o:p></span></font></p>
font-family:Arial'></table><o:p></o:p></span></font></p>
font-family:Arial'></center><o:p></o:p></span></font></p>
font-family:Arial'><input type=3D"hidden" =
name=3D"imgxy"
value=3D"[center]"><o:p></o:p></span></font></p>
name=3D"imgext"
value=3D"[mapext]"><o:p></o:p></span></font></p>
name=3D"map"
value=3D"[map]"><o:p></o:p></span></font></p>
name=3D"root"
value=3D"[root]"><o:p></o:p></span></font></p>
name=3D"savequery"
value=3D"true"><o:p></o:p></span></font></p>
name=3D"program"
value=3D"[program]"><o:p></o:p></span></font></p>
value=3D"[map_web_imagepath]"><o:p></o:p></span></font></p>
name=3D"map_web_imageurl" =
value=3D"[map_web_imageurl]"><o:p></o:p></span></font></p>
value=3D"[map_web_template]"><o:p></o:p></span></font></p>
font-family:Arial'></form><o:p></o:p></span></font></p>
font-family:Arial'><p><hr><p><o:p></o:p></span></font><=
/p>
font-family:Arial'><a href=3D"[root]/index.html">back to
start</a><p><o:p></o:p></span></font></p>
font-family:Arial'><i>[map_web_template]</i><o:p></o:p></span=
></font></p>
font-family:Arial'></body></html><o:p></o:p></span></font></p=
</div>
</div>
</body>
</html>
------=_NextPart_000_0004_01C44CC8.C30C4D30--
