[Mapserver-users] Autonumbering of labels?
Lowell Filak
lfilak at medinaco.org
Mon Jun 7 10:45:41 EDT 2004
The following message was sent by Doug <ummmmm at myrealbox.com> on Mon, 07
Jun 2004 08:39:46 -0500.
> Steve Lime wrote:
> > Nope, that functionality doesn't exist. For clarification, you mean only
> > the
> > features actually labeled? That may be tough because labels are
> > assigned before
> > being queued for rendering and this would need to be far more dynamic.
> > If you could expand on your idea that would help...
> > Steve
> >>>>Brad Cantwell <bcantwel at us.ibm.com> 6/3/2004 1:56:37 PM >>>
> > Is there a way to do sequential numbering for labels? We would like
> > to
> > have the labels for features autonumbered (i.e. 1 though N). Is there
> > a
> > way to do this through the .map file? We are trying to avoid
> > MapScript
> > if possible.
> I work with Brad, and here's what we need to do. We have a layer of
> specific locations that we need to show on the drawn map. However, we
> need the locations to be numbered somehow such that for any particular
> map, the numbers always start at 1. i.e. dynamically giving a temporary
> "ID" to each location based on what is currently visible.
> One person suggested creating a dynamic database view with an
> autonumbered column, but we haven't succeeded with that approach yet.
> We were also wondering if there are other options.
> Doug
I know your trying to stay away from MapScript but I would suspect with
it you could do a queryByRect (current extents) on the points layer and
then loop through the resultCacheObj for each resultCacheMemberObj
grabbing the shapeindex for the current point and create a pointObj for
that shapeindex in the layer and then use the pointObj draw method
specifying the 'character text' value as the sequential number.
Clear as mud...
Lowell
