[Mapserver-users] what is the distinction
Delfos, Jacob
jacob.delfos at maunsell.com
Tue Jun 8 03:29:34 EDT 2004
The one in the map object is global. It applies to all layers except if
specified otherwise inside the layer object. Having a projection definition
in the layer object allows you to mix datasets with different projections.
If the layer is in the same projection as specified in your mapfile, you can
leave out the definition of the layer.
