[Mapserver-users] what is the distinction
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue Jun 8 04:01:48 EDT 2004
boli schrieb:
> As projection object is defined both in map object and layer object, is there any distinction between those two projection object?
> Thanks.
> ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡boli
> ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡boli611 at hotmail.com
> ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡2004-06-08
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Boli,
they can be different if you mean this - this is the idea. You use some
parameters or an epsg code (you can look at http://www.epsg.org) to
define the "source" of your coordinates. Because of that you must always
provide the right projection for your data. Then the mapserver can
reproject it to the projection of the whole map. The projection of the
map is free for choice depending on your needs. You can set that to
whatever it should be.
Regards,
Norbert
