[Mapserver-users] mapserver and extern interfacing
Emil Zegers
EZS at DeStraat.NL
Tue Jun 8 08:37:46 EDT 2004
Hello Sébastien ,
You can do this by using MapServer as a WMS or WFS client.
Take a look at http://mapserver.gis.umn.edu/doc.html for info on the following items:
OGC WMS Client
OGC WMS Server
OGC WFS Client
OGC WFS Server
Also take a look at the Wiki on http://mapserver.gis.umn.edu/cgi-bin/wiki.pl for more info on WMSMapServer and WFSMapServer.
It is not exactly like sending a .shp to MapServer but might suit you needs.
Best regards,
Emil Zegers
>>> Sébastien DUBOIS <sebastien.dubois at esm2.imt-mrs.fr> 06/08/04 01:28pm >>>
hi all,
if you take allok to the proprietary software like arcims soft, you'll see that
most of these soft works like servlets and allow interfacing with other
servlets which give them .xml or other.
my query is to know if mapserver can work like this.
Let's explain this more .
yet it's possible to use a database like postgresql to load layer.
but is it possible to send .shp to mapserv for a layer from an extern source
(without work with the database as a intermediary)
in other words is there an api of mapserv which allow to custumize this soft?
thanks in advance
Sébastien
This mail sent through IMP: http://horde.org/imp/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________
VChecked
______________________________________________________
This message has been checked for all known viruses
