[Mapserver-users] Map file LAYER - PROJECTION definition from
MapInfo tif .tab file
Frank Warmerdam
warmerdam at pobox.com
Tue Jun 8 11:23:26 EDT 2004
Trent Burton wrote:
> Can someone tell me the projection entry into a map file for the
> following Mapinfo tif .tab entry, or better yet, explain to me how this
> works?
> !table
> !version 300
> !charset WindowsLatin1
> Definition table
> File "35j04_1614.tif"
> Type "RASTER"
> (347739.77,6898820.51) (0,0) Label "Pt 1",
> (349059.02,6898820.51) (5277,0) Label "Pt 2",
> (349059.02,6897411.01) (5277,5638) Label "Pt 3",
> (347739.77,6897411.01) (0,5638) Label "Pt 4"
> CoordSys Earth Projection 8, 33, "m", -76.5, 0, 0.9999, 304800, 0
> BOUNDS (-7943519.03923, -10000965.5329) (8553119.03923, 10000965.5329)
> Units "m"
Trent,
There isn't a very handy way of doing this. I translated it by substituting
it into a .mif file and using ogrinfo to get a WKT representation of the
coordinate system:
PROJCS["unnamed",
GEOGCS["unnamed",
DATUM["MIF 33",
SPHEROID["GRS 80",6378137,298.257222101],
TOWGS84[0,0,0,-0,-0,-0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-76.5],
PARAMETER["scale_factor",0.9999],
PARAMETER["false_easting",304800],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Which I would manually translate to be:
PROJECTION
"+proj=tmerc +lat_0=0 +lon_0=-76.5 +k=0.9999 +x_=304800 +y_0=0 +datum=NAD27"
END
> I assume that SUPPORTS=PROJ means that my mapserver was compiled with
> PROJ.4?
Yes
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
