[Mapserver-users] Projection and/or Extent problem
Dylan Keon
keon at nacse.org
Wed Jun 9 16:33:29 EDT 2004
The LAYER projection definition looks incomplete, for one thing. If
you're working with just a single layer the projection definitions
aren't really necessary - try commenting out all of the projection
definitions (both in the MAP block and the LAYER block) and see if that
makes a difference.
It could also be an EXTENT problem, but try the projection stuff first.
--Dylan
On 6/9/2004 1:11 PM, Eric Fegraus wrote:
> Hello,
> I'm beginning with Mapserver. Have it installed on Linux with Apache.
> I'm trying to make an image of one of my shapefiles. The image is
> created but the size of the shapefile as part of the image is about
> 1/100 the size of the image (i.e. most all the image is white and the
> shapefile appears in the top left corner of the image). Have a feeling
> it must be due to my extent and/or Projection. Any ideas?
> Thanks!
> Eric
> Start of map file
> MAP
> IMAGETYPE PNG
> NAME Test
> STATUS ON
> SIZE 400 400
> EXTENT 283091.000000 352956.000000 7529638.000000 7427241.000000
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> # Projection definition, consult the PROJ.4 documentation for
> parameter discussion
> PROJECTION
> "proj=utm"
> "zone=36"
> "south"
> "ellps=WGS84"
> "datum=WGS84"
> "units=m"
> "no_defs"
> # OR:
> # "init=epsg:32736"
> END
> #-- Begin layer defs.---------------------
> LAYER
> PROJECTION
> "proj=utm"
> "datum=WGS84"
> END
> NAME SOILS_shape
> TYPE POLYGON
> STATUS DEFAULT
> DATA SOILS_shape
> CLASS
> OUTLINECOLOR 128 128 128
> COLOR 225 225 185
> END #-- End class def.
> END #--End Layer def.
> END #-- End Map File
Dylan Keon - GIS Coordinator
Northwest Alliance for Computational Science and Engineering
Oregon State University
Corvallis, OR 97331
keon at nacse.org voice: 541-737-6608 fax: 541-737-6609
http://gis.nacse.org
