[Mapserver-users] crash using srs parameter in getmap request
craig.gould at bt.com
Thu Jun 10 09:17:03 EDT 2004
Tom,
If John's crash is anything like the crash I experienced then it is the
actual mapserv process on the machine that crashes with a null pointer
exception somewhere.
This crash only happens with certain types of projections. I was using
British National Grid (BNG). The native projection of the WMS server was
BNG, and the native projection of the WMS client was BNG. However if I
include the SRS parameter then the map server process on the WMS server
crashed (however not if you used a browser and did a standard request).
If I took out the SRS parameter via a redirecting page the process did
not crash.
Upper and lower case made no difference for me. The application still
crashed.
BTW, when I found this problem I posted it on this list, but got no
answer back. Since then at least two other people have posted similar
problems. Each time I've let them know how I got round the problem.
Unfortunately I can't get seem to get map server to compile on my win
machine so I can't look into where this may be happening.
Craig.
-----Original Message-----
From: Kralidis,Tom [Burlington] [mailto:Tom.Kralidis at ec.gc.ca]
Sent: 10 June 2004 14:04
To: Gould,CR,Craig,XGH6A C; john.pulles at geodan.nl;
mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] crash using srs parameter in getmap
request
Comments:
- What do you mean by MapServer crashing? Are you getting a 500 error?
Are you getting an OGC Service Exception Report XML document?
- What is the *native* projection of the data? This is what should be
declared in the PROJECTION block foreach layer
- try your "wms_srs" declaration with lowercase (i.e. "init=epsg:28992")
- trying a WMS GetMap request without the SRS keyword is an invalid
request, and should throw an exception
- WMS is not the problem. A WMS shall support all SRS projections it
advertises in Capabilities
..Tom
Tom Kralidis
Systems Scientist
Environment Canada
Tel: +01-905-336-4409
http://www.ec.gc.ca/
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Sent: Thursday, June 10, 2004 7:33 AM
> To: john.pulles at geodan.nl; mapserver-users at lists.gis.umn.edu
> getmap request
> John,
> I and a few others have found the same problem.
> The way round it is to create a web page that is called
> instead of the opengis mapserver. This page forwards the
> request to the mapserver but strips out the SRS paramater. If
> the map server is using the projection you want returned by
> default, then everything ends up OK. BTW this only happens
> with certain projection types. Regards, Craig.
> John Pulles
> Sent: 10 June 2004 10:28
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] crash using srs parameter in getmap request
> Hi List
> Using a map file with projection settings as shown below, I
> get a crash of mapserver when doing an opengis getmap request
> with &srs=epsg:28992. With an absent srs parameter or with
> &srs=epsg:4326 a correct map is returned. Does anyone have an
> idea what could be wrong?
> BTW: I am using MapServer version 4.2-beta2 on W2K, with the
> PROJ_LIB environment variable set to the directory containing
> the epsg file.
> Regards,
> John Pulles.
> MAP
> NAME "Demo"
> PROJECTION
> # RD
> "init=EPSG:28992"
> END
> EXTENT 10000 305000 280000 619000
> SHAPEPATH "c:\kaarten"
> UNITS meters
> WEB
> METADATA
> "wms_title" "Demo"
> "wms_srs" "EPSG:4326 EPSG:28992"
> END
> END
> LAYER
> NAME provincies
> DATA "provincies"
> STATUS ON
> METADATA
> "wms_title" "Provincies"
> END
> TYPE POLYGON
> CLASS
> COLOR 212 212 212
> OUTLINECOLOR 0 0 0
> END
> PROJECTION
> # RD
> "init=EPSG:28992"
> END
> END
> END
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
