[Mapserver-users] Mapserver doesn't create image, no crash
Möri Cédric
Cedric.Moeri at bd.so.ch
Fri Jun 11 04:06:48 EDT 2004
Hi Berend
sadly engouh I've got no hint for you. We are suffering of exactly the same
problem:
We are running about 15 projects/mapfiles on the same cgi, but the problem
occurs only in one project which worked fine in 3.6.
I reduced the number of layers in the project from about 25 to 10, but still
the same. We tried all your ideas also with no success. We also tried to
eliminate all LABELCACHE and POSTLABELCACHE in the mapfile.
We are running MapServer 4.0.1 on RedHat 7.2.
If anyone has an idea or the solution of the problem please let me/us know!
Best regards
Cédric
> -----Original Message-----
> From: Berend Veldkamp [mailto:berend.veldkamp at aris.nl]
> Sent: Wednesday, June 09, 2004 6:58 PM
> To: Mapserver Users
> Subject: Re: [Mapserver-users] Mapserver doesn't create
> image, no crash
> It seems html code is stripped from messages, so here it is again:
> At 17:50 6/9/2004, Berend Veldkamp wrote:
> >Hi,
> >I'm in the process of upgrading an old mapserver CGI (3.4)
> application to 4.2. I have most things working now, but it
> seems that now and then mapserver doesn't create a map image
> (there's nothing in the tmp dir).
> >Instead, I get the following output:
> (This part was stripped):
> - An emtpy HTML page, with the output of mapserv -v as a comment -
> >It seems it depends on which layers I have turned on, and
> which area I'm
> >zoomed in to. However I can't find a clear pattern,
> sometimes I have to
> >turn on a particular layer to make it work, other times I
> have to turn
> >off a layer.
> >When I turn on logging in the WEB object, I get this:
> >Wed Jun 9 17:37:32 2004,21917,127.0.0.1,vl,0,172329.357920
> >438926.688000 196177.642080 453219.312000,0.000000
> 0.000000,route bkgrnd
> >nummers roads landuse ,normal execution
> >Wed Jun 9 17:37:42 2004,21928,127.0.0.1,vl,0,172329.357920
> >nummers roads toerinfo landuse ,
> >On the second line, 'toerinfo' is turned on, and I don't get
> the 'normal
> >execution' message.
> >I have no idea where to start looking, so any hints are appreciated.
> >I already tried (to no avail):
> >- Different ouput format (jpeg, png, png 24 bit)
> >- Upgrading GD to 2.0.26
> >- Removing all antialiasing, backgroundcolors, pixmap symbols etc,
> >reducing the number of colors from >1000 to 15
> >- Tried MS 4.0 and 4.2
> >Thanks in advance, Berend
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
