[Mapserver-users] Dynamic Features
Eduardo Spremolla
edspremolla at antel.com.uy
Fri Jun 11 08:53:14 EDT 2004
Jonathan:
this is what I do in www.trackbysat.com. Is a heavy hacked version of
map_quakes from the perl wiki. I don't use Postgis when I build this
site, now I do ;-)
First collect the points. I plot actual position plus a line with the
last 10 reports, so after the query:
$result = $conn-> exec($sql);
while(@row = $result->fetchrow)
next if ($row[1]==91);
$reporte[$i]{ lat} =$row[1];
$reporte[$i]{ lon} =$row[2];
$reporte[$i]{ hora} = $row[0];
$reporte[$i]{ io} = $row[3];
$reporte[$i]{ vel} = $row[4];
if ( $i == 0){
$primero{ lat} =$row[1];
$primero{ lon} =$row[2];
$primero{ hora} = $row[0];
$primero{ io} = $row[3];
$primero{ vel} = $row[4];
$i++;
$ret = $conn->requestCancel;
Then I plot some base maps:
die $mapscript::ms_error->{message} unless $map = new
mapscript::mapObj($my_map);
&set_extent();
my $img = $map->prepareImage();
# draw basemap
my $layer = $map->getLayerByName('fondo');
$layer->draw($map, $img);
$layer = $map->getLayerByName('plazas');
$layer = $map->getLayerByName('ejes');
$layer = $map->getLayerByName('calles');
$layer = $map->getLayerByName('avda');
$layer = $map->getLayerByName('vial');
#set the dinamic layers
my $layer_t = $map->getLayerByName('timestamp');
$layer_t-> { status} = 1;
# turn the layer on
my $layer_p = $map->getLayerByName('movil');
$layer_p-> { status} = 1;
# turn the layer on
Then create the points and lines:
$layer = $map->getLayerByName('reporte');
my $point = new mapscript::pointObj();
my $line = new mapscript::lineObj();
my $i = 1;
foreach my $q(@reporte)
$point-> { x} = $q-> { lon};
$point-> { y} = $q-> { lat};
$line->add($point);
my $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
$shape->add($line);
$shape->draw($map, $layer, $img);
$etiqueta="$q->{hora}\|${spee}km/h";
if ( $q->{vel}> $maxspeed )
{ $cl = 2; }
else
{ $cl = 1; }
$point->draw($map, $layer_t, $img, $cl, $etiqueta);
$i++;
And final draw everything :
$map->drawLabelCache($img);
$img->saveImage($image_path.$image_id, $map-> { imagetype} , $map-> {
transparent} , $map-> { interlace} , $map-> { imagequality});
$img=$map->drawScalebar();
$img->saveImage($image_path.$scalebar_id, $map-> { imagetype} , $map->
{ transparent} , $map-> { interlace} , $map-> { imagequality});
Hope this will help
LALO
Eduardo Spremolla <edspremolla at antel.com.uy>
Antel I+D
