[Mapserver-users] still need wfs help
bartvde at xs4all.nl
Fri Jun 11 16:41:53 EDT 2004
the things you are trying won't work.
Within is not supported, see the GetCapabilities interface for what is
supported.
Here is an example I use:
http://localhost:81/cgi-bin/mapserv.exe?map=/ms4w_20/apps/general/map/gemeentes.map&SERVICE=WFS&VERSION=1.0.0&TYPENAME=Gemeentes&request=getfeature&Filter=%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EGEMNAAM%3C/PropertyName%3E%3CLiteral%3EAmsterdam%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/Filter%3E
The filter is then in a more readable format:
<Filter>
<PropertyIsEqualTo>
<PropertyName>GEMNAAM</PropertyName>
<Literal>Amsterdam</Literal>
</PropertyIsEqualTo>
</Filter>
Try reading more about Filters in the OGC Filter specification.
Best regards,
Bart
> I´trying to do some queries (CGI mode) using the parameters PropertyName;
> FeatureId and Filter but with no sucess (i´m using mapserver version
> 4.2-beta2).I´m based on the examples that I found in WFS Specification
> (page 80). I´m trying things
> like:http://www.someserver.com/wfs.cgi&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&typename=INWATERA_1M&PROPERTYNAME=INWATERA_1M/WKB_GEOM,INWATERA_1M/TILE_ID&FEATUREID=INWATERA_1M.1013but
> the results are the same with or without those parameters.And what about
> Filter parameter? Is is supported by mapserver?Should the following
> example
> work?;Filter;Within;PropertyName;PropertyName;gmlox;gml;coordinates;/gml:coordinates;/gmlox;/Within;/Filter
