[Mapserver-users] ia64 php mapscript compile error
Lars Holm Loldrup
LLO at CARLBRO.DK
Mon Jun 14 05:16:11 EDT 2004
I had this problem, and it was solved by adding -fpic to ALL compilations.
regards Lars Loldrup
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of AARON
KONING
Sent: Sunday, June 13, 2004 1:00 PM
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] ia64 php mapscript compile error
Hi List,
I am having the following problem when attempting to
compile PHP Mapscript on Linux Suse under an Altix
64bit server. The error as shown below is: '@gprel
relocation against dynamic symbol'. I have read that
it may be be due to the fact that "...non-pic object
files are linked into a shared library. The ia64
compiler _requires_ that all code in a shared
library is compiled with -fpic."
I have set CXXFLAGS equal to PIC and then recompiled
PHP and mapserver/mapscript but I still get the same
error. Anybody have any thoughts on this?
Linux Suse OS: 2.4.21-215-itanium2-smp
gcc: 3.2.2
PHP: 4.3.7
MapServer: 4.0.2
---------- ERROR:
# make
g++ -shared -o php_mapscript.so php_mapscript_util.o php_mapscript.o
mapscript_i.o -L/usr/local/src/gissrc/mapserver-4.0.2 -lmap
-L/usr/local/lib -lcurl -lssl -lcrypto -ldl -lz -L/usr/local/pgsql/lib
-lpq -L/usr/local/lib -lgdal.1.1 -lproj -ltiff -ljpeg -lfreetype -lpng
-lz -lpdf -L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz -ljpeg -lm
-lstdc++
/usr/lib/gcc-lib/ia64-suse-linux/3.2.2/../../../../ia64-suse-linux/bin/ld:
/usr/local/src/gissrc/mapserver-4.0.2/libmap.a(maplexer.o): @gprel
relocation against dynamic symbol msyystate
relocation against dynamic symbol msyystring
relocation against dynamic symbol msyyreturncomments
relocation against dynamic symbol msyyin
relocation against dynamic symbol msyyout
relocation against dynamic symbol msyylineno
collect2: ld returned 1 exit status
make: *** [php_mapscript.so] Error 1
---------------------- END ERROR
Thanks,
Aaron
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
