[Mapserver-users] MUM2 WMS failed
Dean Gadoury
dgadoury at dmsolutions.ca
Mon Jun 14 08:33:43 PDT 2004
Hi Eduardo,
If you want an online WMS viewer to test the connection you can try:
http://www.wmsviewer.com/main.asp
Dean
Eduardo Patto Kanegae wrote:
>Hi,
>I tried to access the link http://dev1.dmsolutions.ca/cgi-bin/mswms_mum2 using JUMP but got the following error:
>java.io.IOException: Server returned HTTP response code: 400 for URL: http://dev1.dmsolutions.ca/cgi-bin/mswms_mum2?request=capabilities&WMTVER=1.0
> at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
> at java.net.URL.openStream(Unknown Source)
> at com.vividsolutions.wms.WMService.initialize(WMService.java:71)
> at com.vividsolutions.jump.workbench.ui.plugin.wms.URLWizardPanel.exitingToRight(URLWizardPanel.java:127)
> at com.vividsolutions.jump.workbench.ui.wizard.WizardDialog.nextButton_actionPerformed(WizardDialog.java:269)
> at com.vividsolutions.jump.workbench.ui.wizard.WizardDialog$3.actionPerformed(WizardDialog.java:210)
> at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
> at javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(Unknown Source)
> at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
> at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
> at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
> at java.awt.Component.processMouseEvent(Unknown Source)
> at java.awt.Component.processEvent(Unknown Source)
> at java.awt.Container.processEvent(Unknown Source)
> at java.awt.Component.dispatchEventImpl(Unknown Source)
> at java.awt.Container.dispatchEventImpl(Unknown Source)
> at java.awt.Component.dispatchEvent(Unknown Source)
> at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
> at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
> at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
> at java.awt.Window.dispatchEventImpl(Unknown Source)
> at java.awt.EventQueue.dispatchEvent(Unknown Source)
> at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
> at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
> at java.awt.Dialog$1.run(Unknown Source)
> at java.awt.Dialog.show(Unknown Source)
> at java.awt.Component.show(Unknown Source)
> at java.awt.Component.setVisible(Unknown Source)
> at com.vividsolutions.jump.workbench.ui.plugin.wms.AddWMSQueryPlugIn.execute(AddWMSQueryPlugIn.java:83)
> at com.vividsolutions.jump.workbench.plugin.AbstractPlugIn$1.actionPerformed(AbstractPlugIn.java:121)
> at javax.swing.AbstractButton.doClick(Unknown Source)
> at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
> at javax.swing.plaf.basic.BasicMenuItemUI$MouseInputHandler.mouseReleased(Unknown Source)
> at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
> at java.awt.EventDispatchThread.run(Unknown Source)
>a question: does it have something to do I am behind a proxy server?
>is there WMS/WFS browser website available on the web? so that I don't need to connect from my machine to the server... it shold go from the website to the server.
>thanks
>http://www.consultoria.eti.br
>UIN: 303747254
>Treinamento em UMN MapServer - http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
>I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
>Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
>***Fim da Mensagem / End of Message ***
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dean Gadoury
DM Solutions Group
30 Rosemount Ave. Suite 200
Ottawa, Ontario. K1Y 1P4
613.565.5056 ext. 24
www.dmsolutions.ca
More information about the MapServer-users
