[Mapserver-users] MUM2 WMS failed
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Mon Jun 14 12:32:53 EDT 2004
Hi Dean,
thanks. it works fine!
each point is a user that was at MUM2( and accepted to be shown on map ) ?
sounds good. shows us how mapserver is evolving world round.
does anyone can estimate how many mapserver users are there over the
whole world? 1000 ? or more?
best.
Eduardo
Dean Gadoury escreveu:
> Hi Eduardo,
> If you want an online WMS viewer to test the connection you can try:
> http://www.wmsviewer.com/main.asp
> Dean
> Eduardo Patto Kanegae wrote:
>> Hi,
>> I tried to access the link
>> http://dev1.dmsolutions.ca/cgi-bin/mswms_mum2 using JUMP but got the
>> following error:
>> java.io.IOException: Server returned HTTP response code: 400 for URL:
>> http://dev1.dmsolutions.ca/cgi-bin/mswms_mum2?request=capabilities&WMTVER=1.0
>> at
>> sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown
>> Source)
>> at java.net.URL.openStream(Unknown Source)
>> at com.vividsolutions.wms.WMService.initialize(WMService.java:71)
>> at
>> com.vividsolutions.jump.workbench.ui.plugin.wms.URLWizardPanel.exitingToRight(URLWizardPanel.java:127)
>> at
>> com.vividsolutions.jump.workbench.ui.wizard.WizardDialog.nextButton_actionPerformed(WizardDialog.java:269)
>> at
>> com.vividsolutions.jump.workbench.ui.wizard.WizardDialog$3.actionPerformed(WizardDialog.java:210)
>> at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
>> at
>> javax.swing.AbstractButton$ForwardActionEvents.actionPerformed(Unknown
>> Source)
>> at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown
>> Source)
>> at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
>> at
>> javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
>> at java.awt.Component.processMouseEvent(Unknown Source)
>> at java.awt.Component.processEvent(Unknown Source)
>> at java.awt.Container.processEvent(Unknown Source)
>> at java.awt.Component.dispatchEventImpl(Unknown Source)
>> at java.awt.Container.dispatchEventImpl(Unknown Source)
>> at java.awt.Component.dispatchEvent(Unknown Source)
>> at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
>> at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
>> at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
>> at java.awt.Window.dispatchEventImpl(Unknown Source)
>> at java.awt.EventQueue.dispatchEvent(Unknown Source)
>> at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown
>> Source)
>> at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown
>> Source)
>> Source)
>> at java.awt.Dialog$1.run(Unknown Source)
>> at java.awt.Dialog.show(Unknown Source)
>> at java.awt.Component.show(Unknown Source)
>> at java.awt.Component.setVisible(Unknown Source)
>> at
>> com.vividsolutions.jump.workbench.ui.plugin.wms.AddWMSQueryPlugIn.execute(AddWMSQueryPlugIn.java:83)
>> at
>> com.vividsolutions.jump.workbench.plugin.AbstractPlugIn$1.actionPerformed(AbstractPlugIn.java:121)
>> at
>> Source)
>> Source)
>> at javax.swing.AbstractButton.doClick(Unknown Source)
>> at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
>> at
>> javax.swing.plaf.basic.BasicMenuItemUI$MouseInputHandler.mouseReleased(Unknown
>> Source)
>> Source)
>> Source)
>> at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
>> at java.awt.EventDispatchThread.run(Unknown Source)
>> a question: does it have something to do I am behind a proxy server?
>> is there WMS/WFS browser website available on the web? so that I
>> don't need to connect from my machine to the server... it shold go
>> from the website to the server.
>> thanks
>> http://www.consultoria.eti.br
>> UIN: 303747254
>> Treinamento em UMN MapServer -
>> http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
>> I Encontro Nacional de Usuários MapServer -
>> http://mapserver.cttmar.univali.br/encontro2004
>> Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
>> ***Fim da Mensagem / End of Message ***
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
UIN: 303747254
Treinamento em UMN MapServer - http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
