[Mapserver-users] cgi-apt-get debian
james cradock
jcradock at redington.me3.com
Tue Jun 15 07:16:55 EDT 2004
Lars,
What's the output from Apache's error log? It should be in
/var/log/apache/error.log. Or try this from a terminal (command line)
window:
tail -f /var/logl/apache/error.log | grep mapserv
Jim
(I've resent this from the email address the list knows about.)
> hello list,
> has someone installed mapserver via apt-get on debian?
> it installs the mapserv under /usr/lib/cgi-bin/mapserv
> calling the file directly gives:
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> that should be ok.
> calling mapser -V gives:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> that is also ok.
> if I copie the file (mapserv) in the cgi -directory of the apache and
> calling it from the web i get internal server error.
> what is wrong?
> thanks for ideas and help
> lars
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
james cradock
