[Mapserver-users] mod_perl segfaults
Eric Bridger
eric at gomoos.org
Tue Jun 15 09:03:18 EDT 2004
On Mon, 2004-06-14 at 21:45, Sean Gillies wrote:
> On Jun 14, 2004, at 1:30 PM, covad at ert.dyndns.org wrote:
> > I'm getting errors like the following:
> > [Mon Jun 14 14:22:49 2004] [notice] child pid 19412 exit signal
> > Segmentation fault (11)
> > in my apache error log, but only intermittently. The site is usable,
> > but
> > craps out ~25% of the time.
> > I'm running perl mapscript 4.2.0, apache 1.3.31, and mod_perl 1.29.
> > Has anyone else seen behavior like this?
> > Would rolling back to mapscript 4.0 help?
> > Thanks,
> > -rob
> Rob,
> I don't have specific mod_perl experience but am using mod_python and
> mapscript
> in production. There's a few differences between them but I might be
> able to help
> you a bit. I am using Apache 2.0.40-something.
> Are you trying to keep a mapObj as an application global by executing
> code like
> $map = mapscript::mapObj('file.map');
> in the startup script? If you do, you have to be very careful that you
> don't have
> different requests trying to access and modify this same mapObj. The
> best thing
> to do would be to create a pool of mapObj instances and fetch one from
> the pool
> to satisfy requests, or clone the master mapObj for every request. Or
> create a
> new instance from a file on disk for every request.
For what it's worth, we are running Apache 1.3.28, mod_perl 1.28,
mapscript 4.2.0 on FreeBSD 4.8 and have not seen any seg faults. But we
are not trying to use global map objects.
Eric
