[Mapserver-users] beginner in mapserver
Fortin,Nicolas [SteFoy]
nicolas.fortin at ec.gc.ca
Wed Jun 16 08:36:25 PDT 2004
Hi Eric,
I don't know much about mapinfo but .map from mapinfo is not the same file format as the .map from mapserver. Mapfile from mapserver is plain text file and you have to do it yourself to use your data.
Hope this helps,
Nicolas
-----Message d'origine-----
De : mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] De la part de Belenfant Eric
Envoyé : Wednesday, June 16, 2004 10:59 AM
À : Mapserver-users at lists.gis.umn.edu
Objet : [Mapserver-users] beginner in mapserver
i'm a beginner in mapserver.
I try to use mapserver on a W32 with PHP 4.3.3 and maps from MapInfo 6.5. First notice:
I get the files from MapInfo (.DAT, .MAP, .IND, .ID)
Then, as they say in the tutorial, i try changing the dataset in the
.MAP mapfile
I open the .MAP but it's a binary file impossible to understand.
So what is the mystake ??
Should i create another .map in txt format and refer to the files coming
from MAPINFO ??
I'm lost !!!!
thanks a lot for your answer
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
