[Mapserver-users] MapInfo example (was: thanks for your answers guys)
Tyler Mitchell
tjmitchell at riverside.bc.ca
Wed Jun 16 12:48:22 EDT 2004
Sorry for the poor (non-existant) formatting, looked kinda cruddy once the
HTML headings were stripped out. I'm attaching a slightly better formated
version below...
MapInfo Files
Also known as TAB or MID/MIF files.
File listing
The following files are also associated with .TAB files: .DAT, .ID, .MAP.
An example is:
border.DAT border.ID border.MAP border.TAB
The term MID/MIF refers to files with .MID and .MIF extension.
Data Access / Connection Method
1.TAB and MID/MIF access is available in MapServer through OGR.
2.The CONNECTIONTYPE OGR parameter must be used.
3.The path to the (*.tab or *.mif) file is required, and file extension is
needed.
4.The path may be relative to the SHAPEPATH
5.DGN files already contain "styling" information. This styling
information can be used (optionally) by specifying the STYLEITEM "AUTO"
parameter in the LAYER object of the mapfile.
6.If you use STYLEITEM "AUTO" you must have an empty class in the layer
OGRINFO Examples
ogrinfo on a single TAB file
$ ogrinfo elev5_poly.TAB
Had to open data source read-only.
INFO: Open of `elev5_poly.TAB'
using driver `MapInfo File' successful.
1: elev5_poly (Polygon)
Using ogrinfo to examine the structure of the file/layer
$ ogrinfo elev5_poly.TAB elev5_poly
Layer name: elev5_poly
Geometry: Polygon
Feature Count: 2236
Extent: (-141.000000, 60.000000) - (-124.403310, 69.300251)
Layer SRS WKT:
GEOGCS["unnamed",
DATUM["MIF 0",
SPHEROID["WGS 84 (MAPINFO Datum 0)",6378137.01,298.257223563],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
AREA: Real (0.0)
PERIMETER: Real (0.0)
ELEV5_: Integer (0.0)
ELEV5_ID: Integer (0.0)
TYPE: Real (4.0)
ELEV5: Real (4.0)
Mapfile Syntax
LAYER
NAME Elevation_Poly_5
TYPE POLYGON
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "./hypso/elev5_poly.TAB"
STYLEITEM "AUTO"
CLASS
NAME "Elevation Poly 5"
END
PROJECTION
"proj=latlong" "ellps=WGS84" # Geographic
END
END # Layer
