[Mapserver-users] Compile error
Alexandros Chimarios
alhim at intracom.gr
Thu Jun 17 02:49:14 EDT 2004
On Thursday 17 June 2004 08:16, Kralidis,Tom [Burlington] wrote:
> Hi,
> I'm running into issues in deploying MapServer.
> Info:
> - OS: Fedora Core 2
> - supporting libs installed in default locations
> I've included my terminal session in trying to compile (attachement
> build_output.txt).
> Note that it's looking for the libpq lib. I even tried copying
> /usr/local/pgsql/lib/libpq* to /usr/local/lib, but ldd still gives me
> problems for libpq.
> Any suggestions are valued.
> Thanks
> ..Tom
> Tom Kralidis
> Systems Scientist
> Environment Canada
> Tel: +01-905-336-4409
> http://www.ec.gc.ca/
Hi Tom,
if you just add the /usr/local/pgsql/lib directory (and/or any other
directories for libraries needed ) in your /etc.ld.so.conf file and run
ldconfig, then you will be able to run the mapserv CGI.
Alexandros
