[Mapserver-users] Compile error
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Jun 17 09:10:17 EDT 2004
> -----Original Message-----
> From: Nicolas Boretos [mailto:nicolas at maich.gr]
> Sent: Thursday, June 17, 2004 2:18 AM
> To: Kralidis,Tom [Burlington]
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Compile error
> Kralidis,Tom [Burlington] wrote:
> >Hi,
> >I'm running into issues in deploying MapServer.
> >Info:
> >- OS: Fedora Core 2
> >- supporting libs installed in default locations
> >I've included my terminal session in trying to compile (attachement
> >build_output.txt).
> >Note that it's looking for the libpq lib. I even tried copying
> >/usr/local/pgsql/lib/libpq* to /usr/local/lib, but ldd still
> gives me
> >problems for libpq.
> >Any suggestions are valued.
> >Thanks
> >..Tom
> >Tom Kralidis
> >Systems Scientist
> >Environment Canada
> >Tel: +01-905-336-4409
> >http://www.ec.gc.ca/
> Hi Tom,
> I usually add the shared lib directory to the /etc/ld.so.conf
> file, and
> then I do
> an "ldconfig" in that directory, to update.
> Some OS's e.g. Solaris sometime need explicit lib path, e.g.
> LD_LIBRARY_PATH="path to libs...." : export LD_LIBRARY_PATH
> regards,
Yiasou,
That worked like a charm!
Thanks
..Tom
> nicolas boretos
