[Mapserver-users] Unable to access file. set in index.html
Swaminathan, Gayathri
gayathri at ou.edu
Thu Jun 17 10:42:19 EDT 2004
Hi:
Could you post the map file/ template file...
Also, what version of mapserver?
What is the configuration you see when you run "mapserv.exe" from command prompt...
Are there any missing dlls prompted?
Thanks
Gayathri
> -----Original Message-----
> From: COUTUJF at dfo-mpo.gc.ca [mailto:COUTUJF at dfo-mpo.gc.ca]
> Sent: Thursday, June 17, 2004 9:38 AM
> To: Swaminathan, Gayathri
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE : [Mapserver-users] Unable to access file. set in
> index.html
> Hello,
> unfortunately, when I try to use the template I get the message:
> Content-type: text/html msReturnPage(): Unable to access
> Hence I don't have much info when doing a "view source".
> JF
> -----Message d'origine-----
> De : Swaminathan, Gayathri [mailto:gayathri at ou.edu]
> Envoyé : 17 juin 2004 10:00
> À : COUTUJF at dfo-mpo.gc.ca; mapserver-users at lists.gis.umn.edu
> Objet : RE: [Mapserver-users] Unable to access file. set in index.html
> Hi:
> So in your browser when you are trying to use the template, I
> assume you are getting an "image not found" box...
> Can ya right click or "View Source" to see if your image url
> appears right? Should be something like
> http://serveraddress/workshop/tmp/<imagename.png>
> not http://serveraddress/./workshop/tmp/<imagename.png>
> (The image url .\workshop\tmp\ does not look right to me)...
> Another thing to check would be is if your "tmp" directory is
> published as a virtual directory in your webserver. (but
> since you are saying you get this
> http://serveraddress/workshop/tmp/filename.png ...that seems
> to have been configured right)
> Gayathri
