[Mapserver-users] adding input from ascii text file
Vincent J. Troisi
Vincent.Troisi at colorado.edu
Tue Jun 22 10:48:08 EDT 2004
An example of a text file follows. The file is static (does
not change). I prefer not to load the information into a
database and, although the table could be modified, I prefer
not to modify the table.
Vince
Site Latitude Longitude Easting Northing
R701 41.9643` -93.6848 443253 4646040
R702 41.9542 -93.6407 446901 4644894
Tyler Mitchell wrote:
>>What is the best method for adding features to a
>>map from an ascii table?
> Are they just point coordinate pairs? Are you looking to automate
> grabbing the locations from the text file - i.e. as the file changes - or
> will you accept a manual approach? Are you able to modify the structure
> of the table if you need to or are you stuck with what you are given?
> Can you give us a sample of a few lines of the data?
> Tyler
