Hi All,
I've installed mapserver, and use OGR to pull data from Oracle. I
have no problem creating images from this data, but am having problems
with WFS. As long as the bounding box is small (about the area of
Missouri), and the data is simple, I can retrieve a gml document using
the following query for state data:
http://xxxx/cgi-bin/mapserv42?map=/data/source/catalogv2.map&request=getFeature&version=1.0.0&service=WFS&typename=states&bbox=-96.7,35.7,-88.37,41.2
This query only takes a few seconds. However, if I sample another
layer that contains more data (like my counties layer), the data being
download starts out at about 40K per second and begins to quickly drop
down to slower than 1K per second. The bigger the bounding box or
larger the dataset, the worse it gets. It almost seems like an
exponential time complexity problem, but I don't know where the
problem lies.
Here is a clip from my map file:
LAYER
NAME "states"
CONNECTIONTYPE OGR
CONNECTION "OCI:xxxx/xxxx at test9i"
DATA "OGC_CATALOG.STATES"
# STATUS OFF
TYPE LINE
PROJECTION
"init=epsg:4326"
END
CLASS
STYLE
COLOR 0 0 0
END
END
DUMP true
METADATA
WMS_TITLE "State Boundaries"
WMS_ABSTRACT "These are state boundaries"
WMS_SRS "EPSG:2613"
WMS_EXTENT "-130 20 -60 50"
WFS_TITLE "State Boundaries"
WFS_EXTENT "-130 20 -60 50"
WFS_SRS "EPSG:4326"
WFS_GEOMETRY_ELEMENT_NAME "geometry"
END
END
LAYER
NAME "counties"
TYPE line
CONNECTIONTYPE OGR
DATA "OGC_CATALOG.COUNTIES"
PROJECTION
"init=epsg:4326"
END
TYPE LINE
CLASS
STYLE
COLOR 200 200 200
END
END
DUMP true
METADATA
WMS_title "County Boundaries"
WMS_ABSTRACT "These are county boundaries"
WMS_SRS "EPSG:2613"
WFS_TITLE "County Boundaries"
WFS_SRS "EPSG:4326"
END
END
Thanks,
Timothy Rupe
Programmer
USGS Mid-Continent Mapping Center
