[Mapserver-users] Projection issue...
Jason M. Nielsen
jnielsen at aero-graphics.com
Tue Mar 2 13:59:09 EST 2004
Anyone see anything wrong with the following?
As far as I can tell the rest of the map file etc is ok. I pushed this all over
into the itasca demo to try and debug what I have goofy. All I am getting is a
black area as if I have an extents problem.
TIA
# SLC section in WGS 84 Lat Long Decimal Degrees
NAME SLC
STATUS ON
SIZE 558 360
#WGS84
EXTENT 40.1 -112.8 40.6 -111.4
UNITS DD
SHAPEPATH "data"
IMAGECOLOR 0 0 0
IMAGETYPE PNG24
[root at localhost data]# ogrinfo -al slc2002photos.shp | more
INFO: Open of `slc2002photos.shp'
using driver `ESRI Shapefile' successful.
Layer name: slc2002photos
Geometry: Point
Feature Count: 392
Extent: (-112.064000, 40.263300) - (-111.471300, 40.500400)
Layer SRS WKT:
PROJCS["WGS_1984_TM_36_SE",
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",10000000.0],
PARAMETER["Central_Meridian",36.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
This mail sent through IMP: http://horde.org/imp/
