[Mapserver-users] Image size out of range ...
woodbri at swoodbridge.com
Thu Mar 4 12:41:18 EST 2004
I don't see this in the Documentation I have printed here, please
write a doc bug on that.
-sw
On 4 Mar 2004 at 11:23, Daniel Morissette wrote:
> Frank Rittinger wrote:
> > I want to create output images that exceed the default image size of
> > 1024x1024. Are there any penalties in changing MS_MAXIMAGESIZE_DEFAULT
> > to something like 4400 or even larger?
> > How exactly does MS_MAXIMAGESIZE_DEFAULT = 2048 relates to a max size of
> > 1024x1024? I.e. if I want to have an image size of 1613x2200 what would
> > be the required MS_MAXIMAGESIZE_DEFAULT?
> My understanding is that MS_MAXIMAGESIZE_DEFAULT = 2048 means that you
> can have up to 2048 pixels in both dimensions (i.e. max of 2048x2048).
> So if you want to allow 1613x2200 images you should set it to 2200.
> > Or is there a way to override the default at runtime?
> Since version 4.0 (not sure about 3.6), you should be able to set
> MAXSIZE 2200 at the top-level in your mapfile to override the default.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
